Old 11-20-2010, 03:18 PM   #1
peterporter
Drives: toyota yaris
Tight Steering
Have a 02 yaris non power steering. The steering has recently stiffened and doesn't self centre. Any ideas? Thanks, Pete
peterporter is offline   Reply With Quote
Old 11-21-2010, 09:56 AM   #2
it's possible the rotating bearing on top of the struts have seised. I had some go bad on mine.
To check, you can jack the front of the car off the ground and turn the wheels by hand. have a look at the springs and see if they're binding up and popping free.
It's also possible you have a tear in you inner tie rod end boot, and now the steering rack is rusted or dry.
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Is this normal with the Yaris steering lock? STC General Yaris / Vitz Discussion 13 07-06-2010 10:15 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
Steering Wheel Spacers? BassAssassin Cosmetic Modifications (Exterior/Interior) 0 08-12-2009 12:52 PM
