Old 12-04-2010, 07:59 PM   #1
Maitre_Te_Te
Drives: Yaris 08
LB and sedan
Hello. I work for Toyota and I have seen zero difference between Yaris sedan and Yaris LB(HB) for the engine. Last week, a member from another forum say the engine is not exacly the same. Do you have seen any diffrence beacause my opinion is this member have not reason.
Maitre_Te_Te is offline   Reply With Quote
Old 12-04-2010, 09:29 PM   #2
MUSKOKA800
MUSKOKA800's Avatar
I believe the concensus on this forum would be that the powertrains are identical. Things look slightly different when you look under the hood only because of the physical differences in the body shape.
Old 12-04-2010, 09:37 PM   #3
only difference is the length of the exhaust...
Old 12-04-2010, 11:21 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
The platform and drivetrain are the same, otherwsie these two cars share very little in common... as they were designed in different countries by quite separate entities of Toyota. In Japan, the sedan (Belta) is sold in Toyota stores, while the HB (Vitz) is marketed by Toyota's Netz division.
Old 12-04-2010, 11:28 PM   #5
Maitre_Te_Te
Drives: Yaris 08
this is exacly what I think!
Old 12-05-2010, 01:02 AM   #6
Chuck G
Drives: 2010 Yaris Sedan
Great info!!
