Old 12-11-2010, 02:29 AM   #1
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Mono Signal
Okay i have a KDC-X794 headunit and a Hifonics BXI-2010d which is asking for a mono signal to the subs. It says to run a Y adapter from one of the channels of the headunit to send a mono signal to the amp. I've skimmed over my user manual on the headunit and it doesn't say which channel " left or right " it recommends to kick a mono signal from..So it shouldn't matter correct ?
Old 12-11-2010, 10:03 AM   #2
enve1160
Drives: yaris
Your right, left or right channel will work. It doesnt matter which one you use.
enve1160 is offline   Reply With Quote
Old 12-14-2010, 12:26 AM   #3
_S7V7N_
_S7V7N_'s Avatar
A question i just though of also is if you're head unit pushes 4 v out the pre out then does it drop it to 2V when you connect it to the amp, or it's a mono so it doesn't drop ? My fix is going to be a Knu Konceptz Krystal Cable Subwoofer RCA 4 Meter http://www.knukonceptz.com/productDe...prodID=KRY1.4M
And this Y splitter right at the amps http://www.knukonceptz.com/productDe...rodID=KRY-1F2M
Old 12-14-2010, 05:21 AM   #4
enve1160
Drives: yaris
I just looked up the specs for both the KDC-X794 headunit and a Hifonics BXI-2010d. All you will need is a 2 channel rca cable. (No Y splitter needed) Your stereo has a mono subwoofer out which consists of two rca plugs. The mono block amp also has an input of 2 rca plugs.
Order this: http://www.knukonceptz.com/productDe...odID=KARSS2.6M.
This is the 6 meter/ 18 foot cable. depending how you route the wire you could use the shorter one. As for me, all my installs i've done I always use the 18 footer to be on the safe side.
BTW there is no voltage drop if you use a Y splitter. You will have 4 volts coming out of each channel, but you dont have to worry about this in your setup.
Hope this helps
Old 12-14-2010, 07:56 PM   #5
_S7V7N_
_S7V7N_'s Avatar
This is what Kenwood had to say ...
Thank you for contacting Kenwood USA Corporation. We value you as a Kenwood customer and appreciate the opportunity to be of assistance.
I understand you are inquiring on the best option for outputting a signal for a Mono amp.
The selection of R/L channel would be the same type of signal from the Head unit to your amp.
Please feel free to contact us again with any additional questions.
Steve
Product Support Representative
PO Box 22745
Long Beach, CA 90801-5745
Phone: 1-800-536-9663 x 1918
Fax:
Email: http://www.kenwoodusa.com/Contact/
Mini meet & greet, Signal Hill. yaris-me California 68 04-16-2010 12:58 AM
Connect mono amp. + subwoofer to stock HU? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 23 10-28-2008 10:01 PM
FS: Sylvania SilverStar 7507AST - Signal Light Bulbs Violin Items for Sale by private party 17 09-13-2007 08:38 PM
Turn signal audible alert paultyler_82 Performance Modifications 7 10-01-2006 10:21 AM
