Old 12-14-2010, 07:55 PM   #1
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Whirring Noise from Rear Left side
So originally I thought it was coming from my belt., since it only occured after around 3500-4000 rpm. But yesterday I happened to hear it come distinctly form behind me and to my left. Any idea what this could be? Again this ONLY happens at a certain RPM range, but it does NOT sound like it is comign from the front of the car. I'm stumped.
Old 12-15-2010, 03:29 PM   #2
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
possibly the rear hub bearing
OTA'sTOY is offline   Reply With Quote
Old 12-15-2010, 04:29 PM   #3
salmonz
salmonz's Avatar
Drives: 07 Yaris Sedan
90% positive it is... Had the same on my caravan.
Hub and bearing assy, yaris, w/abs, rear $288/ea US
Hub and bearing assy, yaris, no abs, rear $135/ea US
http://www.trademotion.com/partlocat...&siteid=214001
They're a SOB to get off, so I recommend taking it to a shop to get the work done.
salmonz is offline   Reply With Quote
Old 12-15-2010, 04:59 PM   #4
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Ah god damnit. What could have caused this? And is there any other way to repair it?
Would this also cause drag to the left then?
Old 12-15-2010, 07:15 PM   #5
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Update, so I spoke to a mechanic at work, and he told me that hub bearings can just be tightened. Now I'm wondering if this is the case, are they the bolts mentioned in this picture?
The ones in behind the plate are the ones I'm referring to.
Are the optional airbags worth it ? avenno2g7 General Yaris / Vitz Discussion 46 12-07-2008 02:40 AM
