Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > NY / NJ/ CT / PA
Old 12-26-2010, 11:02 AM   #1
zer013
Drives: Polar White 09' Yaris LB
Install Lowering Springs NJ
Hey guys,
I just got some TRD lowering springs for xmas. Is there anyone in Jersey thg can install them for me? I live in Middlesex county but don't mind traveling. Today or Friday woul be best. Thanks!
-Christopher
zer013 is offline   Reply With Quote
Old 12-26-2010, 11:43 AM   #2
big lo
big lo's Avatar
Drives: 2007 VIOS
Its very easy if you did it yourself, and you would appreciate the work after, you would need an off set wrench 17mm and if its craftmans it will have a 19mm which would be for the front shocks and one allan wrench 6mm. To start off the job start with the rear very simple, loosen up the bottom screw to the shock and use a jack to lower the shock while the car is up. Switch the spring and then start on the other side. The front is simple, some people take off the crowl but you wouldn't need to if you had the off set. Try it and you will learn more about your car, good luck buddy.
Old 12-26-2010, 03:26 PM   #3
zer013
There's a blizzard going on now so I guess today is out of the question. Let me know if anyone can do it this week. I'm available anytime after 6pm or all day friday.
Old 12-26-2010, 10:21 PM   #4
big lo
big lo's Avatar
Drives: 2007 VIOS
Oh your welcome for the info lol
Old 01-08-2011, 04:18 PM   #5
kelevra
2012 CBR1000RR Hoo Yaaa
kelevra's Avatar
Drives: 08 3 door Hatch
He ignored you because he knows your sunning it up in Puerto Rico, while we're suffering the cold harsh NE winters, jaja.
Some people aren't into DIY. How long does it take to change out the front springs?
Not to hijack your tread, but keeping it on topic.. Cuidate.
Former Admin on a Moto site
kelevra is offline   Reply With Quote
Old 01-08-2011, 04:20 PM   #6
45-60 minutes
Old 01-08-2011, 06:03 PM   #7
kelevra
kelevra's Avatar
Would that be me doing it (pretty good mechanical skillZ), or my local Tech?
I wouldn't mind saving some labor costs if I could pull it off myself if it is easy enough.
Old 01-09-2011, 10:35 AM   #8
big lo
big lo's Avatar
Drives: 2007 VIOS
That sounds about right, 45min to an hour, as long as you got a spring compessor you are good, and yeah its hot today lol, holla at me
Old 01-09-2011, 11:03 AM   #9
...and an impact wrench, either air or electric. Job is sooo much easier with an impact wrench.
Old 01-09-2011, 12:44 PM   #10
big lo
big lo's Avatar
Drives: 2007 VIOS
You got that right, but I used old fashion elbow grease to get the job done, but the impact wrench is a life saver too
Old 02-03-2011, 03:15 PM   #11
Jerkratt
Jerkratt's Avatar
u still need help with the install?
"It hurts more when its wet"
Old 02-08-2011, 07:22 PM   #12
Trubin
Trubin's Avatar
Drives: 2009 Toyota Yaris Hatchback
Pls tell us how your springs work, I got a dilemma between TRD and Tanabe springs, I dono which to choose. I want my ride lower but dont know which springs are best.
Trubin is offline   Reply With Quote
Old 02-08-2011, 07:38 PM   #13
TRD. Tanabe too squishy. Also, unless it is the look you like, Tanabe drop ~.2" lower in the back than the front. TRD is an equal drop on all four corners.
Cost to install lowering springs? NJBob DIY / Maintenance / Service 6 04-08-2009 11:53 AM
anyone have DIY install inst for lowering springs swapout??? Stargate YARlantIS General Yaris / Vitz Discussion 1 10-20-2008 03:18 PM
Is it practical to install stiffer shocks without also installing lowering springs? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 01-18-2007 01:23 PM
HOLEY COW 674.75 to install TRD lowering springs dbaxter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 08-09-2006 12:40 PM
