Old 01-05-2011, 01:51 AM   #1
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Slightly used 10mm Ichiba wheel spacers-$49 Shipped
I'm selling a set of Ichiba wheel spacers hat were only on my car for a test fit. They are hub centric, so no need to worry about your wheels shaking off. I painted them black so they would blend in more. I would keep these, but I do not have enough room for the extended lugs to fit properly on my wheels.The wheels weren't machined right, so the studs come out at a slight angle, and make the lug nuts dig into the wheels. PM me if you're interested.
marlondog is offline
Old 01-05-2011, 07:58 AM   #2
Very unlikely that machining is your issue. Once you had the studs in, did you torque on an old lug nut to seat them in tight?
Also, I have the same spacers and found that Ichiba ships with extended studs that are way too long. This makes it extremely difficult to get the studs into the mounting plate. The studs only need to be 10mm longer than OEM, and the ones they ship are more like ~20mm longer. I had to get more appropriate length studs from Napa.
WeeYari is offline
Old 01-06-2011, 02:46 AM   #3
marlondog
marlondog's Avatar
Those boys were in there like swimwear. I tightened them with an open ended lug nut. Like you said, the studs were too long. Do you know for which vehicle your new studs were made for?
Old 01-06-2011, 08:16 AM   #4
Don't know. I took my OEM stud to NAPA and the counter guy rooted through the bins of studs until he found one ~10mm longer with the same knurl diameter.
If it'll do you any good, the NAPA part# is 641-2196
If you didn't do so, I would highly recommend using an impact wrench to seat the bolts. Given the length of the Ichiba studs, I suspect they went in at a slight angle. Without an impact, it is very difficult to pull the studs in absolutely 100%. By the time you've done all you can do by hand, with the mounting plate wanting to spin, the stud head may not be sitting tight around it's entire diameter. The result would be studs installed a slight bit off of true perpendicular to the mounting plate surface.
WeeYari is offline
Old 01-07-2011, 10:56 PM   #5
marlondog
marlondog's Avatar
Wee Dizzle,
I went to NAPA and got the same exact studs you got. I should have no problem with installing them now.
Old 01-08-2011, 11:28 AM   #6
Wee Dizzle
^ I don't understand this.
Good luck, and just make sure you get those suckers seated TIGHT.
WeeYari is offline
Old 01-09-2011, 03:24 PM   #7
daddz07
Drives: Yaris 2008
Send a message via Yahoo to daddz07
I guess the spacers are no longer for sale?
daddz07 is offline
Old 01-09-2011, 04:22 PM   #8
marlondog
marlondog's Avatar
Weren't you suppose to buy camber bolts and spacers from me? What happened?
Old 01-10-2011, 12:58 PM   #9
daddz07
Drives: Yaris 2008
Hey Marlon -
I know. Since holiday came in, all my money saved are eaten alive by the wife!!Plus my son ask a very special gift so i can't say no. Sorry about that.
Right now back to zero to save some for my investment to my nice little old Yaris!!
daddz07 is offline
Old 01-10-2011, 12:59 PM   #10
daddz07
Drives: Yaris 2008
I saw your new rims.. iTS Nice one!!!
daddz07 is offline
FS: Wheel Spacers (5mm and 7mm) 33OH Items for Sale by private party 10 03-04-2011 09:05 AM
Marlondog's Black Friday Sale marlondog Items for Sale by private party 32 01-03-2011 05:03 PM
Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed RedVitz Photo-Video-Media Gallery 18 10-09-2010 03:36 PM
Ichiba / H&R Wheel spacers? kid chino Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-05-2010 01:29 PM
Installed 10mm PG spacers on a 15x7 +25 wheel kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-27-2009 07:10 PM
