#1 |
![]() Drives: 2010 yaris 3 door stick Join Date: Feb 2010
wheel bearings?
I have a Yaris with only 31,000 miles. I have had a loud noise coming from rear of car. took it mechanic said it it sounds like bad wheel bearings? really? i thought bearings lasted a lot longer. anyone else have this problem of loud, droning rear end noise?
rick |
![]() ![]() ![]() Drives: Loaded 2007 mica silver sedan Join Date: Sep 2007
If you bought the car new take it back to the dealer, should be covered under the 3 yr 36000 mile warranty.
#3 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 black yaris Join Date: Oct 2010
^what he said.. also.. check for chopped out tires. has it ever been in a wreck?
#4 |
I'm ready to roll over 95000 on my 2007 and the only problem I had was the replacement of the ABS wheel sensors and wiring harness on the rear wheels, under warranty. The car is almost flawless in its performance and all. I'm surprised at all the problems that seem to be cropping up. My yaris has been the least expensive car I have ever owned and with gas prices starting to spike again I suspect that will continue. Let us know if your dealer takes care of it.
#5 |
LR wheel bearing was replaced yesterday. Covered under warranty by 4000 miles whew! woulda been 500 bucks. Isnt that too soon for a wheel bearing to fail? jeez its a toyota!
#6 |
I still have my 2001 echo now has 232,000 miles only problem cat con at 230,000
#7 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Feb 2010
Yeah, it seems aweful soon for it to fail, but if they thought the car was perfect you wouldnt need a warranty at all. Stuff happens. I wouldnt stress over it. They make many many millions of bearing and some are gonna fail.Your just the lucky owner who got one.
#8 |
![]() ![]() ![]() ![]() ![]() Drives: '09 Yaris carmine red 2d HB Join Date: Jun 2009
It could be. Either that or a tire. BTW/FWIW..... Yes bearings last much longer now now that they did in the past. However, you can still get a defective one or one that was improperly installed. |
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 01:41 PM |
| new wheel? | Nekofelin | DIY / Maintenance / Service | 1 | 08-10-2010 02:37 PM |
| 2007 3 door 350000 miles eats wheel bearings! | webfeet69 | General Yaris / Vitz Discussion | 23 | 12-15-2009 08:20 PM |
| How much would you pay for a warranty supported steering wheel extension? (3d try) | wornways | General Yaris / Vitz Discussion | 36 | 09-16-2009 10:16 AM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
