Old 01-10-2011, 12:17 AM   #1
walt101786
Drives: 07 Toyota Yaris Hatch-Back
tire pressure
Hey guys, got 1 simple question, how much psi I should have on my 07 H/B tire. I am currently running on 185/60/15 with around 35-39ish psi..is it to much? Cus when I set it to 32psi I feel like the steering wheel feels heavy so Iunno....just curious should I go back to 32? Or should I drop it to around 35ish?
walt101786 is offline   Reply With Quote
Old 01-12-2011, 10:53 PM   #2
sosopo
sosopo's Avatar
Drives: 2008 Toyota Yaris LB
well the manual says it should be at 32 psi.....but I always put around 35 psi...and the car feels ok.....i drive a 08 yaris LB
sosopo is offline   Reply With Quote
Old 01-13-2011, 09:56 AM   #3
swidd
Drives: Yaris HB
I used to run the stock tires at 45 psi with no problem, and got 42,000 miles out of them. Ran some other tires at 50 psi.
What matters anyway is the max sidewall PSI which is listed on the side of your tire (typically 44psi). The 32 psi figure is just what Toyota recommends.
Old 01-13-2011, 06:07 PM   #4
bankrobber
Drives: 2007 Yaris Hatchback
I have an 07 HB and run 32 PSI in front tires and 35 PSI in rear. I have 104,000 miles on rear tires and still not down to wear bars yet. Front gets around 60,000 before replacing.
The more pressure you have in tire the less contact with road. Something to think about in wet weather.
Tire pressure ubospawis Middle East 56 08-25-2011 07:12 AM
Single Tire Replacement - Using Pressure Sensor? 1stOne Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-13-2010 11:25 AM
recurring loss of tire pressure toad Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 12-10-2009 05:54 PM
Higher Tire Pressure captainm27 General Yaris / Vitz Discussion 46 01-27-2009 11:17 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 08:09 PM
