#1 |
Drives: Toyota Yaris 2006 1.0 Join Date: Jan 2011
Driveshaft + CV Joint
Hi there
I need a CV Joint complete with driveshaft (left hand Side) and CV Joint without driveshaft (right hand side) for a toyota yaris 2006 1.0. It needs to have 19 splines on the inside and 26 on the outside. Do you by any chance have any of these? Thanks in Advance Gordon |
The left hand side complete shaft is part number 43420-52180. The right side complete shaft is 43410-52180. Those part numbers are different from what is used (and is readily available over here on ebay) for the 1.5L. I needed a front left complete shaft and was able to pick one up for $50 shipped.
| Yaris TS driveshaft and CV question | aucorium | Yaris TS Talk | 2 | 08-06-2010 01:20 AM |
| Yaris TS driveshaft and CV question | aucorium | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 08-05-2010 05:04 AM |
| Ball Joint on Bottom Arm | David Godfrey | DIY / Maintenance / Service | 1 | 04-18-2010 06:27 PM |
| if anyone here needs a custom (or any other) driveshaft, now's your chance. | Tamago | Off-topic / Other Cars / Everything else Discussions | 2 | 07-06-2009 11:59 PM |
| Remember that Toyota/Subaru joint RWD coupe concept? | eTiMaGo | Off-topic / Other Cars / Everything else Discussions | 5 | 11-16-2008 03:33 PM |
