Old 01-17-2011, 05:18 PM   #1
DIY: lowering the Yaris steering wheel
Problem: Racing seats make the steering wheel too high.
Solution: unbolt the steering column, lower it a bit, and bolt in some inserts. I cut some pieces from 1.5" square steel tubing, then drilled a hole in one end and a slot in the other. The slot makes it a little easier to slide it onto the upper stud that used to secure the steering column. The result is pretty low (great for racing), 1" might be a little better for street driving and getting in and out of the car.
Much better!
Old 01-17-2011, 06:37 PM   #2
detroiter
detroiter's Avatar
Too cool man!
Old 01-17-2011, 06:44 PM   #3
annn
ヤリスワールド
annn's Avatar
Drives: 2008 HB
Thumbs up
I like the gauges mounted in the upper box...nice!
annn is offline   Reply With Quote
Anyone Else Hate The Yaris Steering Wheel? PhilD424 Cosmetic Modifications (Exterior/Interior) 55 01-24-2011 07:08 AM
US '09 5-Door LB: How do you remove the steering wheel? IsLNdbOi DIY / Maintenance / Service 5 06-29-2010 11:50 PM
