Old 01-24-2011, 01:56 AM   #1
WankelsRevenge
Drives: 07 Yaris Hatch
Changed water pump, now have a CEL?
I just changed my water pump a few weeks ago, and as soon as I started the car after I got done I was showing a check engine light. I took it to the local advance/auto zone and had it checked out. Error message showed up as bad camshaft sensor on banks 1 and 2. Now I was puzzled both by the fact the Yaris doesnt have two seperate banks, and the fact I didnt touch anythign electronical other then dosconnecting the battery and alternator. Do any of you guys know what I can do to get it to shut off?
Ryan
WankelsRevenge is offline   Reply With Quote
Old 01-24-2011, 07:02 AM   #2
Check the connector on the Camshaft Timing Oil Control Valve, which is located just above the alternator. Many have damaged either the connector or sensor when tightening the alternator.
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 08:04 PM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 09:14 AM
Hmm my water pump failed again!!!! Could it be the pulley?!?! YarisSedan Performance Modifications 64 10-05-2009 09:32 PM
