Old 01-26-2011, 12:35 AM   #1
H3LlIoN
Drives: '09 Yarrrr hatch
xB Ported Throttle Body & 1zz cable driven TB
It's spring cleaning time...I have too much stuff. These throttle bodies are not USDM yaris compliant out of the box.
The 1zz tb is cable driven...big as hell, and *would* be the equivalent swap for an xB motor, except a flange or adapter would be needed to mate it to an existing 1nz DBC intake mani. It's huge though, and should flow well. As is...unsure if sensors work or not. $100 shipped ContUSA - OBO
#2 is a ported and polished Bullfrog throttle body by Gude. He charges like $250 for these, IIRC. Basically, what's done is that it's taken apart, bored out...larger butterfly is machined, reassembled. This is a direct bolt on for the 1nz DBC intake mani, whether it be xB or *otherworldly* yaris/echo/vitz/etc. I know there is a lot of attention concerning Gude lately and the extreme turbo stuff a member here had built, but the truth is my car runs great and I no longer have top end drop off like I did with factory equipment. The only reason I have this is because I sent him an xB TB as a core with the head thinking that I would be able to swap to DBC after the fact. Basically, I hadn't done any research. Tisk tisk. It's doing me no good, so it's up. $150 shipped ContUSA - obo
The red in the pics is the gasket stuff Gude uses to test his butterflys...it will all be gone by the time you get the TB.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline
Old 01-29-2011, 04:15 PM   #2
johnny_vitz
Drives: 2005 Toyota Echo
For #2 - is the bore of the t.b larger than stock? It almost looks like oem size from the rear
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline
Old 02-02-2011, 12:09 AM   #3
H3LlIoN
yes, it's larger than stock. Both of these will fit on xB's, echos, and other-worldly (non-USDM) yarii.
Toyota
Moving Forward
H3LlIoN is offline
Old 02-03-2011, 11:47 PM   #4
johnny_vitz
Can you give me a measurement in mm of both sides of #2, does it come with the I.A.C?
The other t.b is a four bolt and I don't think it will work on the first gen xb or echo's (3 bolt)
Old 02-04-2011, 09:01 PM   #5
H3LlIoN
A) Yes, I can, although I don't have a caliper right now, so it'll be a couple days.
B) Correct, you would have to make an adapter if you wanted to use it, but it's 60mm as opposed to 54 of the stock tb.
Toyota
Moving Forward
H3LlIoN is offline
Old 02-05-2011, 12:20 AM   #6
johnny_vitz
cool, thanks. Just post em up when you can
Old 02-09-2011, 11:35 PM   #7
johnny_vitz
bump ... any luck with the caliper? and are you including the IAC?
Old 02-11-2011, 10:09 AM   #8
H3LlIoN
I am including what is pictured. I still can't find my calipers...I have class today but I'll just pick another set up on the way back. Sry for the delay.
Toyota
Moving Forward
H3LlIoN is offline
Old 02-12-2011, 01:52 PM   #9
H3LlIoN
Dude. I went to 3 different stores here today and nobody had a decent caliper for sale. They all wanted $30 for digital crap. I'll be "near town" tomorrow and I'll grab a set. Haven't forgotten about you though.
Toyota
Moving Forward
H3LlIoN is offline
Old 02-23-2011, 07:36 PM   #10
ANTuno
Drives: 09Yaris+06XB
Will you ship #2 to 00646 - PR?
ANTuno is offline
Old 03-06-2011, 10:26 PM   #11
johnny_vitz
Any luck with measurements?
1zz Throttle Body - what needs to be done to it kac Performance Modifications 25 11-20-2018 06:13 PM
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
Intake to match the 1ZZ throttle body fuji DIY / Maintenance / Service 2 06-17-2009 10:02 PM
Intake for the 1ZZ throttle body? fuji Performance Modifications 9 06-14-2009 12:02 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
