Old 01-30-2011, 11:12 AM   #1
kosy_m
Drives: toyota vitz
Noise comming from ac compressor.
hi ,am having a 2008 vitz(yaris) hatchback .and i am hearing a noise recently when the engine is running and it seems it coming from ac compressor bearing .but AC is working perfectly...is it possible to replace the bearing or any suggestions ....?
kosy_m is offline   Reply With Quote
Old 01-30-2011, 08:07 PM   #2
Are you sure it's the compressor? A loose belt can cause some interesting noises, and also a bad water pump can be noisy as well (and everything is close together there). You can bypass the AC compressor with a belt for a Yaris with no A/C to be sure. If it is a bad bearing, it probably can be pressed out and replaced, but it may be easier/cheaper to replace the compressor with one from a wrecked car.
Old 01-31-2011, 06:27 AM   #3
kosy_m
Drives: toyota vitz
Yes ,it was the AC compressor bearing. It was confirmed by a mechanic who used a stethoscope like thing on the compressor today.He also told it's easy to fit a recondition unit than pulling the bearing out. thanks CTScott and have u got an idea about the price of a recondition unit ?
Old 01-31-2011, 12:03 PM   #4
Over here - Used ones from wrecks sell for $150 to $250 on ebay and remanufactured ones sell for about $350.
Old 02-01-2011, 12:53 AM   #5
nikonmad
Drives: Yaris 1.0
hi kosy m ,
I would be very doubtful it was the compressor.
Dont know if you have a 1.0 liter 12v 1kr-fe engine, if you have , then the water pump would be prime suspect (a known fault).
Tke some photos of the area with your digital camera with flash on.
If you see anything like pink deposits in the area,its gotta be the water pump.
The pump has been modified for the 1kr-fe to a totally different unit which cures the problem.
The stethoscope method of finding the cause can be tricky as the noise will migrate to other belt driven components and try to trick you.
the 1kr-fe is used in the toyota aygo vehicle in europe, lots of yaris gen 2 and aygo owners have had problems with the pump,some after only 4000mls.
http://www.toyotaownersclub.com/foru...owtopic=118041
its a long shot that your vehicle is a 1kr-fe as they are not popular in your area but this may give you some futher ideas .
nikonmad is offline   Reply With Quote
Old 01-25-2013, 06:39 AM   #6
kosy_m
Drives: toyota vitz
hi.. every one,finally got rid of the whistling sound,
Today i went to a mechanic and he renewed the ac compressor pully bearing and thats it.
thanks CTScott,nikonmad.
Old 03-19-2013, 02:26 AM   #7
futuredenied
Drives: 2007 yaris s
did he just change the bearing??? part number???
futuredenied is offline   Reply With Quote
Compilation of Yaris TSBs eTiMaGo DIY / Maintenance / Service 72 07-04-2024 10:36 AM
Strange noise coming from left door of car daibatzu General Yaris / Vitz Discussion 3 11-19-2010 09:58 AM
Noise from the drums.... Lafiro General Yaris / Vitz Discussion 18 05-22-2009 09:49 AM
Blitz S/C "click" noise when engaging? PETERPOOP Forced Induction Forum 6 03-10-2009 11:17 PM
Radio noise.. need help TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 13 12-06-2008 04:21 PM
