Old 01-30-2011, 09:35 PM   #1
severous01
205/55/16
PLEASE DO NOT RESPOND IF YOU'RE GONNA SAY GO WITH 205/50/16 OR ANY OTHER SIZES....I WANNA KNOW ABOUT MY SPECIFIED SIZE ONLY
hey, i have an option to get a complete set of 205/55/16 tires for free, and get basically free tires for life.
i know they're 5% bigger than stock and every website states that's a bad thing to be more that 3% bigger than stock. like it's some kinda bad mojo.
is it really that big of a deal? when my brakes are ready to be changed, i'm going with hawk HPs up front and the micro-image discs in the rear. i think that will be enough to take on the 2% difference in the maximum abilities of the stock brakes. my speedo will be off 5%, i know.
i'm mainly worried about HP/TQ and if the stock engine setup is capable of handling a 5% extra load at all times. and if the brakes are capable of handling the extra 5% diameter of the tires. PLEASE DO NOT RESPOND IF YOU'RE GONNA SAY GO WITH 205/50/16 OR ANY OTHER SIZES....I WANNA KNOW ABOUT MY SPECIFIED SIZE ONLY
Old 01-30-2011, 10:48 PM   #2
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Your likely to run into problems down the line. Anything bigger than 3% will really mess with the speedo think +- 3 or so mph.
Other things you may not be thinking of and things that would cause me a little bit of concern. Going to larger wheels will cause more stress to the wheel bearings and may cause them to fail prematurely the same thing goes with axles. If your car is a stick shift you may see a reduction in clutch life if its a automatic you may see a reduction in transmission life.
I wouldn't be worried so much about brake wear as the vehicle is so light. I changed mine at 70k miles and there was still something along the lines of 80-90% pad life left.
I'm sure the engine can handle the reduction in (wheel)torque but be aware that acceleration will be slower and may require more downshifts then it did before.
If your getting them for free and can deal with the minor issues and possible rubbing then I say go for it.
Old 01-31-2011, 01:13 AM   #3
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
go with 205 50.
Oh wait ....... lol it doesnt matter man go for it its not damage to the engine or tranny so why not
Originally Posted by sw07gt
Old 02-05-2011, 11:28 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
I've seen a number of Vitz running 205/50/17's (with stock suspension) in Japan. That tyre is in fact a bit taller than a 205/55/16. I recall recently seeing some pics of one of our member's sedans with 205/50/17's.
Old 02-06-2011, 09:53 PM   #5
severous01
k-thanks. i'll look at the charts and see what it says. i knwo 205 50 is the recommended larger size for 16" but like i mentioned....basically free for life tires....i cant pass it up if they'll work and not cause detrimental problems.
Old 02-07-2011, 04:23 PM   #6
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
If you're not lowered, it shouldn't be an issue. However, if you are lowered, you will likely rub quite a bit.
