Old 02-03-2011, 06:49 AM   #1
bkndacn
bkndacn's Avatar
Drives: 2009 Toyota Yaris
Springs?
Ok so in the spring id like to get a set of springs but I first have a question... I want to reduce the body roll when doing rough turns but I DO NOT want to lower my Yaris! due to The ground clearance that I need for winter driving.
Will this be obtainable with just a set of stiffer springs?
PS: I plan on also getting a rear sway bar this spring too!
Thanks for you guys' help :-)
I got a ride in Garms' Yaris and got on a plane within 24 hours of each other.... his yaris was faster! I bet if he put wings on it he could get passed all that L.A. traffic!
bkndacn is offline   Reply With Quote
Old 02-03-2011, 07:20 AM   #2
MUSKOKA800
MUSKOKA800's Avatar
The rear anti-sway bar will reduce body roll significantly.
I'm not sure where you will find stiffer springs at OEM ride height. All aftermarket springs that I'm aware of drop the car at least 1" (Eibach) and up to a 2" drop. Coil-overs (with adjustable spring perches) may be your only choice, and a much more expensive route.
One solution may be to choose the springs with least drop and then recover some ride height come winter with taller than spec. winter tires.
Old 02-03-2011, 08:03 AM   #3
bkndacn
bkndacn's Avatar
1" doesn't sound that bad :). Does Garm sell these springs? I just don't wana slam my Yaris.
Old 02-03-2011, 08:29 AM   #4
^ Yes, he does sell Eibach Prokits.
Tein S-tech Springs with Stock shocks combination. daddz07 California 11 08-21-2010 01:49 PM
Tein S-tech Springs with Stock shocks combination. daddz07 Performance Modifications 1 08-09-2010 03:45 PM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
What springs should I get? Help! CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 01-26-2009 06:32 PM
