Old 02-07-2011, 05:46 AM   #1
kaazio
Drives: yaris luna 2003
rear brake light problem
hello,
My rear brake lights dont work when i press the brake pedal. i checked the bulbs and it seemed to be ok, i checked the right lower fuse and it seemed to be ok as well.
what can be the problem?
thanks!
kaazio is offline   Reply With Quote
Old 02-07-2011, 06:13 AM   #2
BLH
Drives: 2007 Yaris Sedan
Did you check the stop light switch, actuated by the brake peddle?
Old 02-07-2011, 06:23 AM   #3
The switch being bad is definitely a possibility, but are you sure you checked the correct fuse (the STOP fuse):
Old 02-07-2011, 09:30 AM   #4
kaazio
I checked the stop fuse ,
And it was ok. In my 2003 yaris the fuse scheme is different from what shown here. Where exactly the pedal switch located?
Thanks
Old 02-07-2011, 09:39 AM   #5
Thanks
On the 2003, the fuse panel is different, but the fuse is still the 10A STOP fuse. The switch is located on the frame of the brake pedal. When the pedal is pressed, the arm of the brake pedal presses the switch.
Old 02-07-2011, 11:56 AM   #6
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
How did you check the fuse ? visually or with a Multi meter ?
Old 02-11-2011, 05:27 PM   #7
Well, it actually releases the switch, but you get the idea.
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
Remote Starter - Tail Light Problem Chrsto4 General Yaris / Vitz Discussion 4 10-31-2009 11:36 PM
