Old 02-07-2011, 06:05 PM   #1
splify
Drives: toyota yaris silver 2002 1.0
dashboard led
Bought a yaris 1.0 2002 silver well smart now all of a sudden the speedo does not work all of the rest of the lights work any ideas out there sorry my first post is like this but it is a smart looking car. Was working inthe morning now not at night.
splify is offline   Reply With Quote
Old 02-07-2011, 07:38 PM   #2
RedRide
RedRide's Avatar
Is this with your parking/headlights on or off?
Old 02-07-2011, 07:57 PM   #3
splify
headlights on as it is night even if i turn headlights off stays the same
Old 02-07-2011, 09:22 PM   #4
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Does the Tach work?
Old 02-07-2011, 10:59 PM   #5
Check the 10A GAUGE fuse
Old 02-08-2011, 04:02 PM   #6
splify
Im a total newbie at this where are the fuses ive only driven old micra before this
Old 02-08-2011, 04:18 PM   #7
The under-dash fuse panel is behind the access panel to the left of the steering wheel (on a left hand drive car) or to the right of it (on a right hand drive car).
This is a diagram of what you will see:
Old 02-08-2011, 06:08 PM   #8
splify
thanks il have a look and see if a fuse is gone hopefully its just that strange one all the other lights on dash work like doors temp and handbrake but not the speedo just shows to tiny red lines if its not the fuse does it look like i need a replacement speedo is it easy to replace a dash is it just plug in
Old 02-08-2011, 10:00 PM   #9
The other lights are powered off the circuits they are associated with, so with the GAUGE fuse out, they would still work.
If it does turn out to be that the speedo is bad, it is not difficult to remove and swap the instrument cluster. Th only issue is that your odometer will read whatever the replacement one reads.
Old 02-13-2011, 07:31 AM   #10
splify
Another update i love the car nice smooth drive i thought by resetting the ecu would solve it but didnt i unplugged the battery left it off for a bit connected back up speedo starts showing then 2mins later starts going dimmer then goes off any ideas before i send it off to the garage.
Old 02-13-2011, 09:14 AM   #11
That is very strange. If you don't unplug the battery, does it still come on for about 2 minutes when you start the car, or does it remain off until you once again unplug the battery?
If the latter is the case, then I would suspect a failure in the drive circuitry for the VFD.
Old 02-13-2011, 02:36 PM   #12
splify
Yes it is the latter looks like its of to the dealer
DIY LED Strip under the door panel charleschia1986 DIY / Maintenance / Service 19 11-05-2011 08:49 PM
dashboard led splify UK 0 02-07-2011 05:59 PM
Green LED Dome Light and Underdash LEDs Installed fnkngrv Cosmetic Modifications (Exterior/Interior) 11 08-20-2010 01:38 PM
LED Strip Lights ecmiyake DIY / Maintenance / Service 0 07-22-2010 11:32 PM
Interior LED Ricey Problem xbr3akd0wnx Cosmetic Modifications (Exterior/Interior) 10 05-06-2010 09:50 PM
