Old 02-15-2011, 12:07 PM   #1
facu1984
Drives: 2007
Exclamation HELP Can't move parking shift!!!
Hello, I have a problem, probably somebody here can help...
I can't move the parking shift out of P !!
I can do it only by pressing the Shift Lock System button down. But still every time I go back to P, if I want to move the car I have to press down the Shift Lock System button down.
Is there a solution for this???
Thanks!!
facu1984 is offline   Reply With Quote
Old 02-15-2011, 12:18 PM   #2
SailDesign
Drives: .
I was going to be a real a-hole, and say "Yes, get a manual", but decided I'm not that nasty. I AM nasty enough to think it would have been funny, though.
I had a Honda wagon that my wife owned do this, and eventually I took to the local garage who sorted it out. Hopefully someone will chip in with a solution.
Old 02-15-2011, 12:26 PM   #3
facu1984
Drives: 2007
I have the manual is not saying anything.
I look all over it and can't believe they don't mention a thing.
Old 02-15-2011, 12:27 PM   #4
The shift lock is controlled by the Shift Lock ECU, which lives in the bottom of the shift assembly.
I would start by checking the ACC, STOP and GAUGE fuses in the under dash fuse panel (as all three are inputs to the ECU).
Also, the brake light switch is a direct input, so make sure that your brake lights are actually lighting up when you press the pedal (to verify that the switch is good).
Finally, I would pop the cover off of the center console and make sure that the 12 pin connector is properly seated to the shift assembly.
TWM Shift Knob SALE Until July 15th! TWM Performance Sponsors Classifieds Area 6 10-30-2009 12:46 PM
Back to school sale Short shifter, Shift Knob, EVERYTHING is on sale! TWM Performance TWM Performance 13 09-29-2009 10:55 AM
TWM Performance weighted shift knobs on sale! TWM Performance TWM Performance 5 06-30-2009 09:58 AM
New shift knobs available from TWM Performance! TWM Performance TWM Performance 3 06-25-2009 04:24 PM
October sale on TWM Performance shift knobs! TWM Performance TWM Performance 1 10-31-2008 05:01 PM
