Old 02-18-2011, 01:45 PM   #1
cabinfevrr
Drives: 2008 yaris 5door RS
how to change an $8 bulb
This procedure is directly from the toyota repair manual for the Yaris Liftback...I got the manual from here: http://www.etimago.com/yaris/repairmanual/Exterior.pdf
okay here we go - this is quite funny.
step 1: set the parking brake and block the rear wheels. raise the front of the vehicle, and put it on jackstands
step 2:
remove the 5 plastic clips at the top of the bumper cover,
1 from each wheel well, and the 8 bolts from the bottom fascia. I like to organize the bolts in a block of wood, oriented from left to right.
Step 3:
disengage the 3 clips on each side, holding the bumper to the fender. tilt the bumper cover forward.
step 4:
unclip the wire connectors for the fog lights( if equipped), and also the block heater cord (if equipped)
step 5:
remove the bumper cover.
step 6:
locate and remove 3 10mm bolts holding the headlight in place. remove the headlight.
step 7:
remove the old bulb and dust boot, taking care not to tear the boot.
step 8:
re-install the new headlight bulb and connect the wires.
step 9:
test that bulb works, after all that effin work you did.
step 10:
the headlight assembly is now ready to be re-installed.
locate the 3 10mm bolts you removed, and put them in. it is impossible to affect the headlight aiming.
step 11:
"installation is reverse of removal."
-re-attach the foglight connectors
-re-install 7 plastic clips
-re-engage 6 plastic clips to the fenders
-re-install 8 bolts from under the front fascia
step 12:
if equipped, cable tie block heater back to grille.
step 13:
remove the jackstands, and lower the vehicle
step 14:
let the happy car smile!
cabinfevrr is offline   Reply With Quote
Old 02-18-2011, 02:25 PM   #2
Nodrog
Nodrog's Avatar
Send a message via AIM to Nodrog
Wow. That's worse then what I had to do for my New Beetle.
If it aint fixed, don't broke it.
Nodrog is offline   Reply With Quote
Old 02-18-2011, 02:45 PM   #3
jemmah
Drives: Toyota Yaris
Headlights
I've been changing a half-a-dozen headlight bulbs per year. Boy!!! Isn't it fun!! If you want to spoil the fun go to Toyota to purchase the bulb from the service department ----- $25.00 to $30.00 dollars (US) per bulb. That really spoils all the fun!!
jemmah is offline   Reply With Quote
Old 02-18-2011, 03:25 PM   #4
LOL
wow, you did WAYYYY too much work there
1. don't need to jack up the car
2. don't need to fully remove the bumper, just take out the 5 clips at the top and the clip in each fender well.
you can pull the bumper forward hinging on the under plastics to get at the bolts for the headlights...
Old 02-18-2011, 08:23 PM   #5
auxmike
auxmike's Avatar
LOL
+1
I just hinge down the front fascia enough to get at what I need. I did this to put in my premium horn set.
Don't waste time making it a "huge" job when it should be just a "big" job...
Old 02-18-2011, 08:26 PM   #6
auxmike
auxmike's Avatar
Oh , I 'm also going on three years straight coming this april with ALL the original factory installed bulbs still working!
WOOT!
Old 02-18-2011, 09:49 PM   #7
MadMax
MadMax's Avatar
LOL
Isn't there a DIY on this here somewhere?
Old 02-18-2011, 09:56 PM   #8
cabinfevrr
LOL
just going by what it said in the factory repair manual - which said to remove the headlight assembly...which meant removing the bumper cover. to be honest, the warranty is now up, so this is really the first bit of work i've done to it, so I wanted to do it right. I jacked up the car because you may notice that i have the RS model which makes the front lip about 1.5" lower than a regular one, plus if i'm taking off the bumper cover I thought it would be a good idea to get my head under there so I could actually see the bolts to remove.
on the plus side, now that the warranty is done, and the fact that I work at a parts house, I'm going to do stuff to this car - i'm thinking an axleback, coilovers, a strut bar, and a rear swaybar. might lower it a little with the coilovers, but living in a place where I sometimes plow snow with the low front end, I might just go about an inch in the front and 2" in the back - hate the raked look.
Old 02-18-2011, 09:57 PM   #9
cabinfevrr
WOOT!
if i'd made it to May, I would have had 3 years with all the bulbs.
Old 02-18-2011, 09:59 PM   #10
cabinfevrr
to be honest, I looked, but I didn't find much other than people upgrading their headlights to HID or silverstars or something of that nature. I didn't look as hard as I could, because I found the FSM pretty quick.
Old 02-19-2011, 08:07 AM   #11
nemelek
DWEED
nemelek's Avatar
Glad that I have garage and do my work inside. Disableing the day time running lights might add years to the life of the light.
Old 02-19-2011, 08:51 AM   #12
cabinfevrr
Yes I'm glad you have your garage too, quite happy for you actually. i keeps it real...on the ice...
that would add years to the bulb life, however it's illegal not to have DRL here. For what it's worth, it's also illegal to not have tails illuminated on any moving or standing vehicle here, so I turn my lights fully on everytime i drive it - so no half voltage drl for me. I got the car may of 2008, so until a week ago at around 70,000 kilometers, when the bulb burned, that's not too bad a bulb life. YMMV
Old 02-19-2011, 09:54 PM   #13
cabinfevrr
not to be a party pooper but like barber said all you really need to do is pop the hood and change the bulbs, with practice you can do it in under 5 minutes
yeah thanks, that was already mentioned several times, thanks for adding that in there again
further, i already mentioned that I just followed the procedure outlined by the FSM - I figure if that's how toyota is going to change my bulbs this way, then it was good enough for me.
Old 02-19-2011, 10:31 PM   #14
auxmike
auxmike's Avatar
You did good.
Next time you'll have it done in half the time.
I might just change my bulbs come spring, BEFORE they burn out!
Three years is probably cutting it real close....
Old 02-19-2011, 11:29 PM   #15
lol, don't kid yourself, the dealer is going to change the bulbs in 10min like i described, and charge for an hour of labour
either way, you'll know for next time...
Old 02-28-2011, 12:40 PM   #16
the_boss
the_boss's Avatar
Drives: 07 YARIS HATCH 5 DOOR
Send a message via MSN to the_boss
did it twice since last August and will probably do it again next week...yea I know a lot of changing but I just got my replacement bulb directly from GE after a nice little email to there customer service department.
the_boss is offline   Reply With Quote
Old 02-28-2011, 08:41 PM   #17
the_boss
the_boss's Avatar
just got a box from GE customer care today with 3 pairs of GE Nightwack to replace the previous ones...I guess I have bulbs for at least 12 months now!
Old 03-01-2011, 04:25 AM   #18
henry33
Drives: yaris1.33
I have change the bulb without dismounting the front bumper and headlight!
you will need lot of patience but it can be done ;)
henry33 is offline   Reply With Quote
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal hasher22 DIY / Maintenance / Service 88 03-06-2014 06:40 AM
DIY - A EASY&FAST way to change headlight bulb ALLBLACK DIY / Maintenance / Service 0 09-18-2010 01:40 AM
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 02:20 PM
How do i change license plate bulb? Centurion2200 DIY / Maintenance / Service 3 09-26-2006 09:01 AM
