Old 02-21-2011, 05:48 PM   #1
CB900F2
Drives: 08 Sedan
Missing trim plug? - Sedan - Rear Seat Floor Box
Hey guys. I had some work done at the dealer and for them to get access to a wire harness (ABS harness), they had to remove my rear seat and some trim around the rear seat area, but it does not look like they would have needed to remove any of the rear seat floor box trim, but I noticed what looks like I am missing one of the trim plugs that holds the floor box plastic trim in place.
Does anyone mind checking your sedan if you have a missing trim plug? It is the centre one just under the seat on the front if you were to lift up the seat a bit.
Thanks guys.
CB900F2 is offline   Reply With Quote
Old 02-21-2011, 06:18 PM   #2
RedRide
RedRide's Avatar
Is that a plug or, is it a screw/fastener that is missing?
Old 02-21-2011, 07:29 PM   #3
CB900F2
Drives: 08 Sedan
Good question, that is basically what I am trying to find out...
Old 02-21-2011, 09:24 PM   #4
If I'm looking at the correct thing in the EPC, there's a plastic "clip" that should be in there:
90467-08186-B4
Old 02-22-2011, 12:18 AM   #5
GeneralDon7
Drives: Yaris Sedan
Well I just ran out and looked in my sedan and mines apparently missing to, I cant think of any repair I have had done that would have required the seats removed
GeneralDon7 is offline   Reply With Quote
Old 02-22-2011, 04:38 PM   #6
tk1971
tk1971's Avatar
If the clip disappeared after service, then this is my #1 pet peeve against dealerships. I've never had a pleasant experience with any dealer, regardless of brand. I had 3 radios put into my 2000 IS300 (the first year model was a complete and utter piece of junk). Each time they did the work, they ended up scratching up something, or leaving dirty fingerprints all over the beige interior, seats, etc.
tk1971 is offline   Reply With Quote
Old 02-22-2011, 05:36 PM   #7
matthewai
matthewai's Avatar
Drives: it is kinda stock
yeah bunch of deebags
Old 02-22-2011, 06:29 PM   #8
swidd
Drives: Yaris HB
What is it about dealership service departments? Are they any less performance oriented or any less dependent on return customers than other non-dealer shops?
Broken 40/60 Back / Rear Split Seat Handle / Lever alex_melodymaker DIY / Maintenance / Service 9 10-31-2009 04:55 AM
