Old 02-21-2011, 09:57 PM   #1
kurisu
Drives: 2009 Yaris
Transporder Key
Hi guys, I bought a 2009 yaris hb but it only came with 1 key. The key itself has a dimple (dot) and a keyless entry. I read several topics on how to add a keyless entry but I also want to get a 2nd ignition key. Dealer told me it will cost around 200-300 bucks for another master.
I checked on ebay and found this. I'm not sure if this will work. http://cgi.ebay.com/ebaymotors/Toyot...ries#vi-ilComp
and if it does, can I program it by myself or only a dealer can do that?
Also, my car has an immobilizer entry. Thanks
kurisu is offline   Reply With Quote
Old 02-21-2011, 10:14 PM   #2
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Yes, you most certainly can get that key off of ebay. I'm not sure of DIY programing but as the ebay seller suggests, you can definitely go to a lock smith to program it for you. Look one up in the yellow pages and give them a ring to see if they can handle it for you.
Old 02-22-2011, 02:46 AM   #3
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
If the RFID chip is the same as the one in your car, there is a set of instructions somewhere on this forum that say how to do it. Steps like opening and closign the door etc.
EDIT: Here it is: http://www.yarisworld.com/forums/sho...19&postcount=6
Old 02-23-2011, 08:48 PM   #4
teddy
Drives: 2008 5-door hatchback
Send a message via MSN to teddy
If I'm not mistaken, that is to program the keyless entry remote. Unfortunately that does not program the transponder chip.
teddy is offline   Reply With Quote
I lost my master keyless entry key, need suggestions.... Frankd1 DIY / Maintenance / Service 19 12-01-2010 11:13 PM
Replacement key / keyless entry mcduck DIY / Maintenance / Service 4 08-30-2010 06:52 PM
Need remote key fraenx DIY / Maintenance / Service 1 06-26-2009 07:29 PM
Key doesn't work jambo101 General Yaris / Vitz Discussion 13 06-10-2009 06:59 PM
My cool fancy new switchblade key with remote =) YarisSedan Cosmetic Modifications (Exterior/Interior) 14 05-14-2009 02:22 PM
