Old 02-24-2011, 02:53 AM   #1
dante2086
Drives: Toyota Yaris 07
Something's wrong with my engine.
First of all, the check engine light is constantly on. And for the love of me I can't find a good place to do a diagnostic in my region.
And when I drive, when I approach a speed of like 140 kmph, the check engine light starts flashing, then I feel this resistance, like the car is slowing itself down. Prior to this, my yaris could go 170 without coughing.
Oh, and it stutters when I start it in the morning. But starts fine the rest of the day.
dante2086 is offline   Reply With Quote
Old 02-24-2011, 03:03 AM   #2
big lo
big lo's Avatar
Drives: 2007 VIOS
I had something similar to you, what I did was unhooked the battery and the system reseted it self, I had a friend scan my car and found nothing. But doin some research I found that it has to do with the throttle sensor. For the other question sounds like you'll be needing a starter soon, I hope that helped
Old 02-24-2011, 03:15 AM   #3
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Going at those speeds with an engine light on and the engine acting funny is a sure recipe for mechanical disaster.
You may want to get that car to a reputable garage to get it sorted or you will be one of the people Thomas Tusser was thinking about when he coined the phrase =
“A fool and his money are soon parted.”
Old 02-24-2011, 03:24 AM   #4
boyer
boyer's Avatar
Drives: Vios/Yaris sedan
you should check your O2 sensor, plugs, TB..
boyer is offline   Reply With Quote
Old 02-24-2011, 07:38 AM   #5
dante2086
I did take it to a so called reputable garage, the light went off, and 3 days later. Guess what, the light came right back on.
Old 02-24-2011, 09:21 AM   #6
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
Take the car to a trusted garage (or a dealer) that can read the diagnostic codes and tell you whats going on. The fact you have a drivability issue and the check engine light is flashing indicates the need for immediate attention. As mentioned above you need to do this immediately!
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 02-24-2011, 10:44 AM   #7
Vinceb
Drives: 2008 5 Speed Sedan
MIL light on is a problem detected, MIL flashing is serious problem or recurring problem. CTScott just had a post on here recently about jumping 2 pins on the plug for the code readers and getting a morris code style number to figure out the engine code problems, maybe he can help.
Vinceb is offline   Reply With Quote
Old 01-20-2013, 02:11 AM   #8
xchronox365
Drives: 2009 Yaris Sedan
I had floored it in mine one night and my light came on and flashed for about 30 seconds then stayed lit. Come to find out it was a misfire in one of my cylinders. replaced spark plugs cause they were cheap easy and fast. 1 month after that, it did it again, first time it was cylinder 4 this time was cylinder 3, guess what, bad COIL PACK. Just ordered a new one of ebay ran $16.45. I believe that to be the issue, if otherwise ill post more but maybe that will help you.
xchronox365 is offline   Reply With Quote
Old 01-20-2013, 02:58 AM   #9
jambo101
jambo101's Avatar
2 years since the original post..
Did it ever get fixed?
What was the problem?
Have Yaris will travel..
Gearbox/diff squeak, poor engine braking Kiz DIY / Maintenance / Service 8 08-01-2009 09:35 AM
90% on short trip. What to do to protect engine? lh59 DIY / Maintenance / Service 22 12-17-2008 09:02 AM
wtb 1nzfe engine blown or working turboyaris Items for Sale by private party 5 04-08-2007 02:03 PM
