Old 02-24-2011, 11:14 PM   #1
wowitswil
wowitswil's Avatar
Drives: 2010 Yaris 5 Door
need help with amp and sub brands.....
would like to upgrade from my pioneer amp and 2x 10" alphasonik subs....
currently installed are 4 pioneer tweeters with 4 infinity kappa perfect and a pioneer p3200bt hu.....would like some recommendations...and price range is not above $300?
thanks guys
silly yaris....octane 93 r for kids!!!
wowitswil is offline   Reply With Quote
Old 02-25-2011, 12:18 PM   #2
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Do you want an amp for the sub only, or an amp to run everything?
If it's just for the sub, I would get a Pioneer mono amp + a 12" sub + ported box, look in Sonic Electronics, all this would be for less than $300
CLA 250, 4MATIC
Old 02-25-2011, 04:04 PM   #3
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
What's the reason you want to trade out ? Is it old, not loud enough, or just have a few extra bucks and want something new.
Which alphasonics do you have the bottom line ones ? mid or the mack daddy top of the line one's
http://www.alphasonikinc.com/subwoofers.html
Reason i ask is the 600 and 800 look pretty beefy.
Old 02-25-2011, 04:18 PM   #4
derickveliz2
Never mind, )o:
CLA 250, 4MATIC
Old 02-26-2011, 10:42 AM   #5
wowitswil
wowitswil's Avatar
http://www.alphasonikinc.com/venclosures.html
i have the dual 10"
running an old pioneer 700...
i want more solid and powerful sound...
Old 02-26-2011, 12:51 PM   #6
_S7V7N_
_S7V7N_'s Avatar
Dude to be honest, I would just try a bigger amp on them, i bet you weren't even hitting half the RMS. (get the model number of your pioneer and we can look that up ) I have been running the Hifonics Brutus Line and have been happy with there stuff. You're asking for Opinions so here's mine Everybody has there personal preference on audio, and i'm not gonna flame any other brand or believe mine is better, it's all on your own personal experience.
This is what i have and i'm pushing two 12 inch kicker comps with no problem @ 1 Ohm
They have an ebay, but these are the guys i ordered two amps from and were pretty good .. http://www.vminnovations.com/product...Amplifier.html
# Type: Mono Block
# 1-Ohm Power Rating 1x1200
# 2-Ohm Power Rating 1x900
# 4-Ohm Power Rating 1x450
# Turn-On Delay/ Mute
# Frequency Response @-3dB: 20-250Hz
# Damping Factor: >250
# Signal To Noise Ratio: > 95 dB
# THD + Noise: < 0.1%
# Variable Input Level Control (RCA/Unbalanced): 0.2V - 9V
# Variable Input Level Control (Mini DIN Balanced): 0.4V - 18V
# Input Impedance: 47k Ohm
# Input Impedance: 20k Ohm
# Power and Specific Diagnostics LEDs
# Protection DC, Short Circuit, Overload
# Power Supply - All MOSFET: Full PWM
# Power Output Circuit Type: Ultra-Fi MOSFET
# Variable Phase Shift
# Phase Change in Degrees: 0-+180
# Variable Low-Pass 24 dB Octave: 35Hz - 250Hz
# Variable Subsonic Filter: 15Hz - 35Hz
# Bass EQ: 0-+18 dB
# Balanced Inputs
# RCA Inputs
# RCA Line Outputs
# Remote Bass Module Included
# Gold Plated Power Terminal Blocks: 4 GA
# Dimensions : 11.42" x 9.45" x 2.52"
Old 02-28-2011, 11:53 PM   #7
wowitswil
wowitswil's Avatar
that can be the case.....imma try upgrading the amp and see if theres a difference...=]
Old 02-28-2011, 11:58 PM   #8
wowitswil
wowitswil's Avatar
btw anyone know how the infinity basslinks perform?
***** these r what i have in the trunk*****
http://www.vminnovations.com/product...nclosure_.html
Old 03-01-2011, 12:07 AM   #9
The Architect
Give Me Resonance
The Architect's Avatar
Drives: 2007 Yaris HB
The basslink is more of a "Bass Filler" than anything, it was my very first "system".
PG TLD22 8V Line Driver
Old 03-01-2011, 12:52 AM   #10
SeriousBlack
SeriousBlack's Avatar
Drives: 2007 Yaris RS HB
If you can find one (I'm sure you can), pick up an Alpine PDX 1.600 mono amp. They are compact, run cool, are cheap as they're being phased out for a replacement, and can push a 12" Type R sub like you would not believe.
The next most important investment you will make is in a good sub box or enclosure. Don't go too cheap - minimum .75" MDF. Yes, it's extra weight in the car but if you are asking these questions, I assume you give a rat's a** about your bass.
Good luck
SeriousBlack is offline   Reply With Quote
Old 03-01-2011, 06:28 PM   #11
wowitswil
wowitswil's Avatar
if u check the link...thats exactly what it looks like in the trunk....still looking at amps
Old 03-19-2011, 05:32 PM   #12
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
i was very happy with all my arc audio products maybe you can look into them
pennyracer is offline   Reply With Quote
Old 03-19-2011, 07:24 PM   #13
sqcomp
Roadrunner Jr.
sqcomp's Avatar
^If I wasn't on a home audio kick right now, I'd be messing with some Arc SE4200's right now...
― Thomas Paine
Old 03-19-2011, 07:29 PM   #14
pennyracer
boydstir
pennyracer's Avatar
like to use a few myself i have looked at them just know it would not stop there more money i would have to spend to handle the horse power
