Old 02-26-2011, 07:20 PM   #1
rnichols
nick
Drives: 2007 yaris
replace alternator 2007 yaris
how do you replace the alternator on 2007 yaris
rnichols is offline   Reply With Quote
Old 02-26-2011, 07:21 PM   #2
rnichols
nick
Drives: 2007 yaris
Old 02-26-2011, 09:44 PM   #3
Check out the "Charging" section of the service manual:
http://www.etimago.com/yaris/repairmanual/
Old 02-26-2011, 11:53 PM   #4
swidd
Drives: Yaris HB
It mentions removing a right side engine under cover. Is this to perform the job from underneath the vehicle, on a lift? Can it also be performed by removing the front bumper? Or do you HAVE to remove the front bumper anyway? Or can it be done from the top?
Old 02-26-2011, 11:59 PM   #5
The Architect
Give Me Resonance
The Architect's Avatar
Drives: 2007 Yaris HB
It can be done from the top without removing the front bumper, I know because I've done it and Ive also had to put on a serpentine belt on the side of the highway, fun stuff.
PG TLD22 8V Line Driver
Old 02-27-2011, 03:17 PM   #6
Klink10
Klink10's Avatar
As stated check out the stickied service manual and get familiar with that section. Understand how the wiring clips to the alt. so you don't break those. Be sure to understand where to apply force when tightening up the belt after replacement. That said I can have one off in 15 minutes from the hood opening.
Old 02-27-2011, 04:02 PM   #7
^+1
Those are good points. Make very sure that you disconnect the battery before pulling the alternator wiring. The large gauge wire is directly connected to the battery with a larger fuse than you want to experience popping.
Also, as mentioned you have to be very careful not to pry against the camshaft timing oil control valve.
Old 12-10-2020, 02:03 PM   #8
yak
yak
Drives: 2007 5 dr yaris
G'day I know this is an old post but, the 14 mm bolt is extremely difficult to access from the top...what do you suggest for tools ??
I'm using 3/8 ratchet w/14mm six point socket but there isn't enough engagement for the ratchet to socket; it hits the idler pulley, no room for a regular extension
ps I have removed the A/C line bracket as noted in the service manual
cheers & thanx
yak
yak is offline   Reply With Quote
Old 12-10-2020, 02:31 PM   #9
cheers & thanx
yak
You must have a fatter head on your socket driver than I do. Mine, tight but doable.
Old 12-10-2020, 04:07 PM   #10
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Have a ratchet wrench?
What the Yaris community needs to take the Yaris to the next level regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 124 04-30-2009 02:03 PM
