Old 03-05-2011, 03:41 AM   #1
Mister Z
Drives: 08 Yaris HB
Question Suspension question?
The purpose of camber bolts to fix any camber issues correct? is there any camber bolts for the rear? and Also are camber bolts necessary if I plan to run negative camber? Thanks everyone!
Mister Z is offline   Reply With Quote
Old 03-05-2011, 08:57 AM   #2
There is no adjustment for the rear.
The bolts you speak of replace the bolts holding the struts to the hub. They allow you to change front camber.
Old 03-05-2011, 10:41 AM   #3
Shims (ie stainless steel washers) placed between the axle and brake drum on the lower two bolts.
Old 03-05-2011, 07:39 PM   #4
severous01
hunter makes a shim kit also. it's much easier and a more direct use for hunter aligners. if you're rear alignment is out and they say that they can't do the rear cuz there's no adjustment...buy a shim kit for 10 bucks and have them install it. specially if they're using hunter machines.
you can buy shims from hunter.com.
Old 03-06-2011, 05:16 PM   #5
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
microimageonline.com also sells rear camber shims
New to Forum -suspension question!! SparkyTheYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 09-09-2010 04:11 PM
Noobie suspension question?? Richie76 Australia 6 12-27-2009 09:27 PM
Yet another suspension question mastaofdisasta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 04-16-2009 02:19 PM
n00b suspension install question The Stig DIY / Maintenance / Service 25 07-12-2007 08:58 AM
Technical Question for the Suspension Gurus KwonSau Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 06-21-2007 11:31 PM
