Old 03-06-2011, 08:04 PM   #1
Mister Z
Drives: 08 Yaris HB
Need help guys!!
I just installed my Tein basic coilovers and I followed the instructions. Yet i hear metal hitting metal in the rear part of the car when I go over bumps or a dip. I thought it was the bottles on top of the damper. I tighten those and yet the problem is still there. Is it possible that the RSB could be the reason? I didn't remove the RSB when I installed the Coilovers. Would that be a reason for the noise in the rear?
Thanks for the help!!!
Mister Z is offline   Reply With Quote
Old 03-07-2011, 09:39 AM   #2
Imagine
Insert sarcasm here.
Imagine's Avatar
Drives: 2009 Black Pearl Sand 3Dr
I'd verify the top mount/bushings are assembled correctly. How low is the car, are you running bumpstops, did you modify their length?
Imagine is offline   Reply With Quote
Old 03-07-2011, 11:43 AM   #3
Mister Z
Drives: 08 Yaris HB
I will double check. But I followed the instrution manual. And im not that low. The car is dropped about 2in from stock. I have no bumpstops on there.
Old 03-07-2011, 12:30 PM   #4
Did you orient the springs correctly, top is on top? and are the front springs on the front?
I know, silly question, but sometimes, customers do make that mistake.
Old 03-07-2011, 12:42 PM   #5
Imagine
Imagine's Avatar
I'd try to jack up the car a little and see if you can move anything around by hand. Don't go full wheels off the ground, just take some weight off. I agree with CY, double check your springs also just to be safe.
If everything looks ok. Try to take some pics of the shock/assembly, maybe something will pop out to someone.
Also, check exhaust clearance. I've seen them hit arms and such from being lowered so much. Not sure how the Yaris exhaust is routed in connection to the arms, just thinking out loud.
Last edited by Imagine; 03-07-2011 at 01:12 PM. Reason: spelling fix to make sense.
Old 03-07-2011, 01:01 PM   #6
Mister Z
Drives: 08 Yaris HB
I will double check that an I get home. Thx!!!
Finally put my wheels on, What you guys think?! Mister Z Photo-Video-Media Gallery 18 09-12-2010 03:19 AM
Oh my God, you guys, you guys (Running around in a Cartman voice) umm_bacon Off-topic / Other Cars / Everything else Discussions 2 09-19-2007 11:35 AM
What do you guys think of the following mods... vacantj Cosmetic Modifications (Exterior/Interior) 9 07-29-2007 07:12 PM
guys with Mobile video equipment nqd In Car Entertainment + Electronics (audio / video / alarm) 3 04-30-2007 10:50 PM
