Old 03-08-2011, 06:25 PM   #1
jaimico
Drives: yaris advance
Coolant level
When I replace my oil some time ago I saw that the coolant level was at a low level mark, so I added up to the maximun indicated in the container.
After some 4,000 kms, once again the coolant level is low, jus about two 3/4" from the original level, and this is something that has never happend before, and there is no leak, what could be causing this now?
jaimico is offline   Reply With Quote
Old 03-09-2011, 09:00 AM   #2
swidd
Drives: Yaris HB
My level is slowly going down... like from high to 25% above low in 1 year.
Old 03-09-2011, 12:21 PM   #3
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
I think it's normal. I just have a jug of coolant on standby to add some more when it gets low. Every year I get the coolant flushed, which seems to help a bit.
devinlamothe is offline   Reply With Quote
Old 03-09-2011, 03:31 PM   #4
jaimico
Well it did not happend during the first two years, and its funny, since the car I had before ( for seven years) that was a diesel car, that engines runs at a lot higer temp, it did not happend.
Old 03-09-2011, 09:14 PM   #5
ecc_33
ecc_33's Avatar
Drives: 2008 toyota yaris
Ive had mine since new in 08. I have never added coolant yet but it is now running on the low mark. Not to worried about it. Nothing is leaking yet so i just keep a eye on it
08 toyota yaris with some big tires lol
02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
ecc_33 is offline   Reply With Quote
Old 03-11-2011, 01:51 PM   #6
detroiter
detroiter's Avatar
Doesn't coolant loose it's density over time, which in return would make it not "rise" as much as it used to?
Old 03-11-2011, 06:21 PM   #7
jaimico
So what says the book about replacing it, how many miles?, if that is the case.
Old 03-11-2011, 07:11 PM   #8
auxmike
auxmike's Avatar
Check for a pink spray inside the hood. That would indicate waterpump leaks..
Old 03-11-2011, 09:14 PM   #9
RedRide
RedRide's Avatar
Aside from an obvious leak, it can be normal for coolant level to decrease over time.
The reason for this is ethylene glycol makes water very "wet".
In other words, an antifeeze/water mix will leak given the most minuscule path where plain water wont.
So, even if you can't find a leak, it can be so small that you can't see it but, over time it can lower the level.
Old 03-13-2011, 06:22 PM   #10
jaimico
Ok, thanks.
Coolant Level in filler neck? CB900F2 DIY / Maintenance / Service 26 05-18-2014 05:09 AM
Inception (movie) Kioshi Off-topic / Other Cars / Everything else Discussions 25 08-10-2010 02:08 AM
Query re: low level coolant indicator tracey540 General Yaris / Vitz Discussion 2 05-12-2010 06:01 PM
Proper coolant level? jay DIY / Maintenance / Service 4 03-22-2009 04:23 PM
GET FREE PS3/360/Wii check it out! marcus Off-topic / Other Cars / Everything else Discussions 23 09-25-2007 06:51 PM
