Old 03-09-2011, 06:41 AM   #1
david_mackk
Drives: Yaris 5dr LB
HELP!! bi-xenon not working??
I just installed my new bi xenon kit for my 10' lb. I have everything wired up as the instructions say so but no light??
If I flick the hi beam I can see the bulb move but still no light??
It's like there is power to it but not to sure if the globe is just dead or what?? Please help me!! Any ideas on what's wrong?
david_mackk is offline   Reply With Quote
Old 03-09-2011, 07:46 AM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
switch the wire...has to be the reverse grounding system..
Old 03-09-2011, 07:50 AM   #3
david_mackk
Which wire? Sorry first time installing them. What's the reverse grounding system?
Old 03-09-2011, 08:10 AM   #4
david_mackk
My kit has no grounding or relay cables it's just a plug n play pretty much
Old 03-09-2011, 09:38 AM   #5
marcus
toyota
marcus's Avatar
switch the wire going to the battery if you got red for positive put that wire on negative terminal and black ofcourse on positive terminal ..that should work..if your not using relay.. switch the socket from the ballast and just turn it around
Old 03-09-2011, 09:51 AM   #6
Vinceb
Drives: 2008 5 Speed Sedan
Toyota headlamps use a ground switching system, this means that there is a common positive and when you switch from high to low the relay switches which side is grounded.
Other vehicles have a common ground and switch the positive side.
Vinceb is offline   Reply With Quote
Old 03-09-2011, 10:44 PM   #7
Lil Abner
Drives: 2009 3dr LB Manual
Do you have any details on the kit you installed?
Basically what the guys said above, the stock bulbs have a constant power, and switched ground for low and high beams.
But I think we need more info to go on. Just double check the wires and get back to us.
Old 03-10-2011, 05:55 AM   #8
david_mackk
Hey guys thanks for the help!
I finally got it. I had a kit with no ground which is apparently the new style.
I took it back to the guy I bought them off I thought they were dodgy but he said the original bulb connection wasn't producing enough power.
He then gave me the new cables with the grounding wires. Hooked them up now it works fine!
Looks great too, really happy with them. Led parking bulbs really make them look a whole lot better too
Old 03-10-2011, 10:54 AM   #9
Lil Abner
Good to hear man!
$120 AUS PER KIT XENON XTREME SLIM HID $120 JDMWAT Items for Sale by private party 0 03-02-2011 02:27 AM
Electric Windows Stopped Working !?!? MattyP DIY / Maintenance / Service 0 09-14-2010 07:20 AM
Valet 712t not working yaris prime In Car Entertainment + Electronics (audio / video / alarm) 2 04-23-2009 06:53 PM
System not working! Kaotic Lazagna In Car Entertainment + Electronics (audio / video / alarm) 20 06-02-2007 08:54 PM
Working at Volkswagen elsteverino889 Off-topic / Other Cars / Everything else Discussions 22 05-07-2007 07:29 PM
