Old 03-09-2011, 10:26 AM   #1
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
Going to add central locks to my 07 LB. This the one?
He guys. I'm ready to add central locks and alarm to my yaris. I've searched the phorumz and I think this is the one I need:
MES Central locks with Avital 3100 Alarm
Is that the one I need? That's from a1electric. I would also like to put a lock/unlock switch in the panel under my emergency brake. And, if possible, a remote liftback open. Is that possible on our cars? Are these the only things I need to do that?
Door Lock Switch Kit- Flush mount
Trunk release solenoid kit
However in reading some of the threads, it was mentioned there was a fairly detailed DIY on the installation of the system in a car that only has manual locks, but I cant seem to find it. Anyone remember it?
Old 03-09-2011, 11:41 AM   #2
You need a cable, not rod actuated kit for the Yaris.
The console switch is fine.
The trunk release solenoid kit is for a vehicle with a trunk. For the hatch you will need a rod type actuator to unlock it.
Then, to pop it you will need a solenoid actuator to do the luck button push function and then some type of popper to lift the hatch off of the latch.
Old 03-09-2011, 01:49 PM   #3
Shinare
Shinare's Avatar
Thanks for catching that CTSCott, is this one the kit I need?
The trunk release sounds like its more complicated than its worth to pop open, but I would like for it to at least lock/unlock with the other two doors. Since you said its a rod type, is this the one I need:
MES Door Lock Actuator (2 wire)
Thanks for all your invaluable help.
Old 03-09-2011, 02:44 PM   #4
Correct on the kit and the 2 wire rod actuator for the hatch.
One of these days I am going to get around to doing the hatch popper on my car. When you wire your car up, you might want to run an extra pair of wires from the keyless receiver to the hatch so that you can add it once I get it all figured out.
Old 03-09-2011, 04:56 PM   #5
Shinare
Shinare's Avatar
^ I will do so! And thanks for all your help, its much appreciated!
Power windows and locks on a 2009 3dr. chilly79 DIY / Maintenance / Service 8 12-15-2010 12:55 PM
looking to add power locks to 07 HB gabriel2012 General Yaris / Vitz Discussion 7 11-23-2010 08:16 PM
Questions and advice required about power upgrading(windows & locks) W.A.S.P DIY / Maintenance / Service 10 07-22-2009 02:59 AM
I ahve a question about door locks Midon In Car Entertainment + Electronics (audio / video / alarm) 19 01-05-2009 01:37 AM
Yakima Q towers and roof mounts (no bars, locks) for sale $125 shipped pxpaulx Items for Sale by private party 6 04-24-2007 10:54 AM
