Old 03-14-2011, 12:15 PM   #1
Geology
Drives: 2009 5 Door Carmine Red
Map Light Removal
Does anyone know how to safely remove the map light console on a '09 5 Door?
I want to relocate the Bluetooth mic there.
Thanks,
The Geologist is a-rockin' and a rollin'!
Geology is offline   Reply With Quote
Old 03-14-2011, 03:26 PM   #2
I just use my fingertips to avoid damaging the plastic or head liner.
Old 03-14-2011, 04:05 PM   #3
swidd
Drives: Yaris HB
I used a thin plastic thing and gently bent it out at the mark.
Was easier to put bluetooth mic on top of the A-pillar.
I hope yours is better than mine: people just hear noise when I use the bluetooth.
Old 03-14-2011, 04:51 PM   #4
Geology
Thanks for the reply, but a few questions:
1: Where is "the mark"?
2: Where and what is the A-Pillar?
Old 03-15-2011, 01:20 AM   #5
limochong
limochong's Avatar
Drives: 2007 yaris sedan
It's not that hard to take it out...first you can pull the light assy. down with your fingers then use your screwdrivers to push in clips while pulling down lights.
there is four clips holding the lights up so two on each sides top and bottom. Probably need a flashlight to see better once you pry it with fingers.
limochong is offline   Reply With Quote
Old 03-15-2011, 08:53 AM   #6
swidd
Drives: Yaris HB
I thought there were little marks on the edge of the map light. A pillar is the plastic pillars next to the windshield. Its easier to drag the bluetooth wire up under the dash above the pedals, and behind the plastic of the A-pillar.
Old 03-16-2011, 06:32 PM   #7
tk1971
tk1971's Avatar
Why not put it on the steering column?
tk1971 is offline   Reply With Quote
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
MAP LIGHT drell42 Cosmetic Modifications (Exterior/Interior) 2 05-21-2007 07:30 PM
