Old 03-16-2011, 08:09 PM   #1
HELP!!! s/c installed, but a couple of issues
issue #1, brakes arent working....is there something i forgot to plug in? its dark now, so i can't really look until the morning
issue #2, i couldnt find the vacuum line to plug into the firewall side of the blitz intake pipe. i just assumed it was for a/c, which i don't have, so i put a rubber cap on it
any ideas?! the car seems to run fine, though completely gutless since i don't have the blitz piggyback installed
Old 03-16-2011, 08:38 PM   #2
cdydjded
Drives: Yaris LB Turbo
Brakes are hard or soft? Most likely you didnt reinstall the vac hose that goes to the brake booster. Even without the piggy back, if you are seeing boost the car has to have some balls. Unless you have a vac leak.
cdydjded is offline   Reply With Quote
Old 03-16-2011, 08:45 PM   #3
A/C doesn't have any connections to the vacuum lines. They go to the throttle body, brake booster, PCV and intake manifold.
Old 03-16-2011, 09:23 PM   #4
ya, the guys on MI say its the vacuum line i couldnt find
car is gutless, btw, cydjedydyeydh
Old 03-16-2011, 09:49 PM   #5
cdydjded
If its gutless then that blower is crap.......
Old 03-16-2011, 10:40 PM   #6
its staypufts, PM sent
and for cydjedejjdjjjjjededd, the piggyback isnt wired....so the s/c doesnt give me any boost (as the pulley is clutched on the blitz)
Old 03-16-2011, 11:13 PM   #7
FINALLY!!!! LOL
Old 03-18-2011, 05:33 PM   #8
MUSKOKA800
MUSKOKA800's Avatar
Get it sorted Adam ... because mines in transit as I type.
Old 03-18-2011, 05:39 PM   #9
^ he does have it figured out. Install, sans wiring is complete. He should be wiring this weekend.
We've also learned a couple of tricks that will certainly help you out when the time comes.
Old 03-18-2011, 10:37 PM   #10
should be going to echo's sunday morning to wire in the piggyback
car made it to toronto and back this evening w/o boost or the ecu
Old 03-21-2011, 10:48 AM   #11
^ so did you get it all worked out?
Old 03-21-2011, 11:28 AM   #12
yessir
boosting as of ~3pm yesterday
couldnt have done it w/ out the steve's
Old 03-21-2011, 05:09 PM   #13
MUSKOKA800
MUSKOKA800's Avatar
Commit those details to memory gentlemen.
Old 03-21-2011, 05:16 PM   #14
^ What's the tracking# status on yours?
Old 03-23-2011, 11:05 PM   #15
MUSKOKA800
MUSKOKA800's Avatar
It's sitting in my basement. Arrived Monday. The DC header in the shed. NST pulley inbound via USPS.
Crazy busy with school and racquetball tournaments until May. Then it's time to spin some wrenches.
Old 03-24-2011, 09:06 AM   #16
thats quite the mod list for the spring, pete!
Old 03-24-2011, 09:57 AM   #17
I'll be laid up.
Old 03-24-2011, 10:20 AM   #18
ill to help if i can make the time...baby #2 coming start of june....could be early
Tanabe NF210 Installed - Question spacemanoeuvres Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 07-15-2007 08:16 PM
LC Prado Fog lights installed!!! Kitt DIY / Maintenance / Service 6 07-08-2007 06:33 PM
System is installed! Venom In Car Entertainment + Electronics (audio / video / alarm) 14 01-28-2007 06:06 PM
Anyone installed a tach mrrock Performance Modifications 1 10-19-2006 09:57 PM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 07:45 AM
