Old 03-16-2011, 09:51 PM   #1
jeeper5usa
jeeper5usa's Avatar
Drives: 2011 Toyota Yaris
07' Instrument Panel in 11'?
I want to put a 2007 instrument panel into my 2011 as I like the look of it better. My question is, can I do it myself? Will the Milage I have override whatever the last milage was and will the gas gauge and everything else sinc up and work or will I need reporgramming of the old cluster by the dealer before installing? Does anyone know if all the connections are the same? Can I just plug and play with the old cluster in my new Yaris? I really like the look over the orange cluster I have.
jeeper5usa is offline   Reply With Quote
Old 03-16-2011, 10:20 PM   #2
Mileage stays with the cluster. The dealer can't even reprogram it, but some third party companies can (but you would have to ship it to one).
Gas gauge, etc. will be fine, as they work off live sensors.
The big issue for you will be the lack of ABS, TRAC, and VSC indicators for your 2011, since the 07 cluster won't have them.
And, yes the connectors/pinout are the same. I have an 08 cluster that I swap back and forth on my 09, as I am doing my YarGauge development and testing.
Old 03-16-2011, 11:07 PM   #3
bladesmith6
Drives: 2007 yaris HB
Do you have any info for those third part companies ? I was lucky enough to find a "s" model cluster with the tach and i would like to get the mileage changed if possible.
bladesmith6 is offline   Reply With Quote
Old 03-16-2011, 11:40 PM   #4
jeeper5usa
jeeper5usa's Avatar
Why is that a big issue? The 07 do have ABS lights? Dont know what the VSC is or why the TRAC light would be an issue? But maybe should keep orginial cluster?
Old 03-17-2011, 12:48 AM   #5
donchae
noob-toob
donchae's Avatar
Drives: 2007 yaris 4dr sedan
i have a 2007 yaris sedan, and it has the light for the ABS. or it may just be a canadian thing
|| "it's a tough job, but somebody has got to do it" ||
donchae is offline   Reply With Quote
Old 03-17-2011, 02:48 AM   #6
Do a web search for odometer repair service
Old 03-17-2011, 02:50 AM   #7
ABS wasn't all that common prior to 09, so finding a cluster with it might be tough. Traction control and vehicle stability control were new in 2010, so no clusters prior will have the indicators for those.
Another option is to change the LEDs. There is a good thread on here with a DIY on changing them.
what is behind the instrument panel henry33 DIY / Maintenance / Service 3 12-10-2010 09:16 PM
Instrument Panel goes out if I turn on my lights ceceb DIY / Maintenance / Service 9 07-08-2010 05:56 PM
Question about replacing Instrument Panel!! Wowzers78 General Yaris / Vitz Discussion 0 03-18-2010 09:25 AM
New instrument panel fmicle DIY / Maintenance / Service 17 07-19-2009 09:09 PM
