#1 |
Yaris Liftback Hoodlift Kit
Just in from Thailand, a hoodlift kit for the Yaris Liftback.
Uses existing hood and fender bolts, no drilling or riveting required. ![]() ![]() Store link: http://shop.microimageonline.com/Yar...it-YLHL001.htm
Micro Image forums, online store and shop are now closed. It was a great eight year run, but it was time to focus on other things. I'm still selling parts on eBay under micro*image seller ID and customers can still make requests for anything specific. Last edited by cali yaris; 03-17-2011 at 07:35 PM. |
![]() ![]() ![]() ![]() ![]() Drives: '08 LB MT Bayou Join Date: Oct 2008
Nice. Interested but need to wait a while. Hopefully you'll still have them in stock when I get around to it.
#3 |
Free Mustache Rides
does it come with both? i want it cause i had to take my hood poooooper out cause of my strut bar.
#4 |
Yes, it comes with two lifts.
Says not recommended for carbon hoods, but they seem to work fine with mine (just a tiny bit on the stiff side).
#5 |
Free Mustache Rides
garm you're killing me...im gonna need those, a new tow hook, and a few other parts soon...
#6 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 black yaris Join Date: Oct 2010
some of these aftermarket hood struts have a release pressure valve to help with the stiffness on carbon fiber hoods.. does this not have one?
#7 |
^ this does not have one. Nor did my old one, or the Redline Tuning one. It works fine.
#8 | |
but since you are my only vendor i use for my yaris, u will be expecting an order from me sometime after april. i just gotta hold all funds til after my vacation. |
#9 |
Just placed an order. Thanks Garm!
#10 |
![]() ![]() Drives: scion xb Join Date: May 2010
yess finally ive been waiting for this kit.. now i can order all my stuffs one time.. thanks garm...
#11 |
Got mine installed this past weekend. The space to mount the lower bracket is pretty tight so do yourself a favor and get a socket swivel attachment and extension if you plan on installing. Made the job much easier as there is very little room to move a box/open end wrench around in there.
It's not a difficult install, just made tedious by the lack of room. I even considered taking off the fender at one point. I didn't use the lock washers that came with the kit as they just made the bracket move too much while tightening it down. The hinge mounts also interfere with the lower bracket a little bit, but I found that if you slide the bracket all the way towards the fender while installing that you can get the bracket on the opposite side of the offending mount so as not to interfere with it. Doesn't leave any wiggle room, but at this position it still allows the lifts to line up well. Lastly, both lifts provided in the kit are needed as the hood is too heavy to be supported by one. I'll post pics if anyone is interested. |
#12 |
Free Mustache Rides
^^^interested
#13 |
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
interested
#14 |
that's right I went there
Drives: '08 Blazin' Blue,'10 Dark Red Join Date: Oct 2008
I want one!! I hate bein broke :(
Mods : 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals. suggestions always welcome
#15 |
Here's a pic of how I installed the lower bracket. It's kind of hard to tell from the picture but it is actually to the left of the hinge bracket. If you don't put it behind it, the bracket will mount at an angle and I found it harder to adjust for the right alignment when it was in that position.
If you look at the lower part of the lift cylinder you'll see a scratch on it that I got when the bracket was installed at an angle and I was trying to adjust it while closing the hood for a test. It got scratched on that piece of fender with the oblong hole in it on the lower left. With the bracket installed as far left as you can get it, it sits square and lines up without needing to tweak it. |
#16 |
![]() ![]() ![]() Drives: 2008 5-door Yaris Hatchback Join Date: Oct 2008
How do you close the hood? Same as the trunk?
Do you have to slam it or does it fall with gravity? Is there resistence when closing the hood? |
#17 |
You close it like you do the rear hatch. Yes there is resistance when closing it so you can't really slam it. Just push it down until it hooks the latch then shove it into the locked position.
I stays up quite well on its own. And I imagine it would fully open by itself if it weren't for the safety catch on the hood latch. |
| KEYLESS ENTRY kit for Yaris Y(GCC version) --- 56k warning | ricepower | Middle East | 9 | 09-25-2014 02:23 PM |
| Yaris radio installation kit????????? | Yarisguy13 | Great Lakes | 2 | 06-03-2007 09:24 PM |
