Old 03-17-2011, 07:13 PM   #1
shameer_k
Drives: yaris sedan
driver seat belt light
for some strange reason my seat belt light does not come on when the car is running and the seat belt unfasten. what can cause this?
shameer_k is offline   Reply With Quote
Old 03-17-2011, 08:28 PM   #2
About the only thing I can think of that could cause it is the 7.5A MET fuse being blown.
Old 03-22-2011, 12:25 PM   #3
shameer_k
Drives: yaris sedan
where is this fuse located?
Old 03-22-2011, 12:57 PM   #4
In the fuse panel that is under the bottom of the dash by the hood release lever.
Old 03-24-2011, 02:21 PM   #5
shameer_k
Drives: yaris sedan
well i got a right hand drive so its behind the passenger glove box. where is the fuse in the box? i am not seeing anything indicating which is which
Old 03-24-2011, 02:53 PM   #6
It's the one labeled MET in this diagram:
Name:  Fuse Panel.jpg
Old 03-27-2011, 04:30 PM   #7
shameer_k
Drives: yaris sedan
ok i now got chance to check the fuse. the fuse is good
Old 03-27-2011, 05:30 PM   #8
OK. The driver's seat belt indicator gets driven by CAN bus message from the SRS ECU to the instrument cluster, so the easiest next step would be to swap your cluster with one from another car with a working indicator to verify that the issue is in the cluster.
Old 03-27-2011, 06:34 PM   #9
shameer_k
Drives: yaris sedan
ok thats going to be kinda hard. i will see what i can do. will let you know if i get it working
DIY - Sparco Race Seat Install Idjiit DIY / Maintenance / Service 16 08-14-2017 09:15 PM
Back Seat Removal... Idjiit DIY / Maintenance / Service 87 02-08-2015 12:07 PM
DIY: Heated Seats for 2006-2011 Yaris CTScott DIY / Maintenance / Service 24 11-04-2012 05:18 PM
Driver Seat Loose!! Help??!!! mhkritzinger DIY / Maintenance / Service 12 01-16-2011 04:57 AM
Aftermarket Driver Seat Bracket Wisher23 Willing to Buy by private party 1 03-24-2009 12:48 AM
