Old 01-10-2007, 01:26 PM   #1
St_G
Drives: Black 2007 Yaris Liftback 1.5
Whcih weighs more?
The 15" steel wheels from Toyota or the 15" Alloys from Toyota?
St_G is offline   Reply With Quote
Old 01-10-2007, 01:37 PM   #2
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
I think steel does..
-- Blen
Old 01-10-2007, 04:57 PM   #3
swng
swng's Avatar
Drives: 06 3-dr auto RS
Size(s) being equal, alloy wheels are usually lighter. Even if they weigh about the same, which is unlikely (if not impossible), steel wheels will need wheel caps and that will mean additional weight.
However, sometimes alloy wheels are married to wider/higher grade tires, then it will be harder to call as far as overall weight is concerned.
swng is offline   Reply With Quote
Old 01-13-2007, 12:00 PM   #4
03Z33
03Z33's Avatar
Drives: TCR10
My 15" steel wheel and tires weighed in at 33lbs. The stock toyota alloy wheel is 0.5" wider, but should still be at least 3-6lbs. lighter than the steel wheel. Tire weight will not be changed much.
03Z33 is offline   Reply With Quote
