Old 03-22-2011, 09:26 AM   #1
willygoodness
Drives: 09 yaris hb
air filter part number? sigh
hi. i've done a search for a k&n panel filter and all i've found was a spanish link and the filter part number it had was one i've ordered before and it didn't fit at all :/ Maybe i'm doing it wrong??
on the k&n website the only part numbers i've found for the yaris were..
- 33-2211
and
- 33-2131
both won't fit :(
this is my filter's dimentions
total height. 2" 52mm
outside/total width 7" 178mm
outside/total length 9.5" 242mm
filter matieral width 5.9" 149mm
filter material length 8.2" 207mm
does anyone have any links or other filter options?
i would rather k&n because thats what i've used in my other cars and i've found them to be much better than standard filters and a wee bit better than other cheaper brands.
willygoodness is offline   Reply With Quote
Old 03-22-2011, 04:05 PM   #2
RedRide
RedRide's Avatar
The K&N air filter number is "33-2360"
I have one in my Yaris.
Old 03-22-2011, 08:40 PM   #3
willygoodness
Drives: 09 yaris hb
excellent!! thanks
Old 04-14-2011, 06:49 AM   #4
willygoodness
Drives: 09 yaris hb
best thing i've done to the car so far.
Old 04-17-2011, 10:32 AM   #5
thepartsmancometh
Drives: '08 LB, '07 WRX
I use a toyota filter (17801-0t030) on the yaris (wife-mobile), so i have no input on how it works for this model.
caveat aside:
as it relates to my car (07 subaru wrx), I will caution against over-oiling though as I have heard of K&N related issues (mostly noticed through used oil analysis showing high amounts of excess particles). just make sure you keep it cleaned to spec!
thepartsmancometh is offline   Reply With Quote
Having trouble fitting the engine air filter 2007yariz DIY / Maintenance / Service 9 10-29-2010 11:23 PM
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 06:36 PM
Anyone know the part number for this? mrbond Cosmetic Modifications (Exterior/Interior) 15 03-30-2009 01:45 PM
