Old 03-23-2011, 10:13 PM   #1
nobleboy
Drives: 2007 Toyota Yaris S LB
Aux Input Wire
I have searched through the forums and read a bunch of different threads on various Aux Input problems, but I haven't found one quite like what I have. I recently purchased a repossessed 07 Yaris LB that had the radio stolen from it. It was fixed before I got to it, but the Aux Input doesn't work.
I have the "Stereo Input Jack," but when I look under the jack, there is no wire or harness plugged into it. Also, when I look at the back of the stereo, there is nothing plugged into the Auxiliary Input spot. I cannot find anything to plug into that spot either.
Another problem that I have found is that there are 2 unknown wires that have been cut and not fixed. One is red, and the other is what looks like a shielded audio cable that has 3 wires inside of the shielding. I am not sure what they do, because the radio and all of its other functions work properly.
I wouldn't mind running my own wire, but I can't find a place to buy the connectors for either end. I know I can't get them from the dealer. I found one here, but I can't buy it and I can't find the other end.
Any help is much appreciated.
nobleboy is offline   Reply With Quote
Old 03-23-2011, 10:19 PM   #2
nobleboy
I guess my main questions are:
1. How can I get my factory Aux Input to work?
2. What are the wires that have been cut for?
3. I haven't been able to locate the wires for the Aux Input, is it possible they are just hidden somewhere?
Old 03-23-2011, 11:16 PM   #3
The Aux wires are part of the harness, so I believe that those two clipped wires are part of the original Aux wiring. I separated the Aux wiring from the harness on Crashy and sold it. Here's a picture of the separated wiring:
Old 03-24-2011, 09:16 AM   #4
nobleboy
If my car has the Aux Jack, then should it have the wiring for it as well? The wires that are cut in my car look similar to the wires from Crashy, but a different color, could I possibly have the wire in there and not be able to see the ends? Should the wire be easy to trace?
Old 03-24-2011, 11:39 AM   #5
The wire is very easy to trace - It goes from the center console, under the auxjack, to the center of the dash. It is just taped into the larger bundle along the way. I would look for a cut wire under the center console. If there isn't one there, nor do yo see the connector laying there, then it probably didn't have the wiring to begin with.
Old 03-24-2011, 04:47 PM   #6
nobleboy
Can you tell what the wire is that has been cut from my picture? I don't know what it could be...I was thinking either the aux jack or the air bags, those are the only things I wouldn't have noticed not working. I can take more pictures if need be.
Old 03-24-2011, 05:17 PM   #7
All of the airbag wires have yellow on them, so I don't believe they are airbag ones. It would help to have pics that show exactly where the cut wires enter a bundle of wires.
Old 03-24-2011, 06:04 PM   #8
BLH
Drives: 2007 Yaris Sedan
Look at picture 4. Where you are holding the wires.
Near the top of the photo. It looks like the other end of the cut bundle you have in your hand.
Taped to the larger bundle.
Old 03-24-2011, 09:16 PM   #9
nobleboy
I took some more pictures. I looked some more and there is definitely no Aux connector lying around under there. The wires go into a bundle that is on the right side behind the AC controls. They go straight up and split somewhere behind the radio and split off down near the floor. Part of the bundle goes back and connects to the gear shift (automatic) and the auto locks. I know they go together, but I am wondering what they operate and if it has something to do with the Aux input that doesn't work.
I also stripped the wire and found 1 red, 1 green, and some bare shielding.
Old 03-24-2011, 09:24 PM   #10
The red and red and green up top definitely look to be the AUX wiring. Oddly though it looks like sedan, rather than LB Aux wiring. On the Sedan aux cable, the shielded red and green are Left and Right inputs and the separate red is the Aux switch.
Old 03-24-2011, 09:48 PM   #11
nobleboy
Yes, I think you're right. I was able to get my hands on a wiring diagram and found this. I actually think that the wires don't connect together, but that the connectors were cut off at both ends. This would explain why I can't find the connectors anywhere. I was able to find part numbers for the connectors:
D74 - 90980-12259
D75 - 82824-21030
Can I order these connectors and make my own wire? If I have to, I can make my own connector from some old computer parts that I have lying around, but I'd rather do it the easy way...
Old 03-24-2011, 09:58 PM   #12
Those part numbers are just the connectors. You would also need the 4 pins for each side. The connectors are probably $10 each and the pins $12+ each from the dealer (and they are not common pins that you can grab from an electronics supply house).
D74 Pins: 82998-24290
D75 Pins: 82998-12870
Old 03-24-2011, 10:03 PM   #13
nobleboy
Actually, after looking for the part numbers, isn't D75 only for the Sedan? Would I need the D79, 8 pin connector? Do you know the part numbers for that?
Old 03-24-2011, 10:10 PM   #14
Your Jack does look like the one that connects to D79: 82824-52330
Old 03-24-2011, 10:21 PM   #15
nobleboy
Does that D79 connector also need special pins in it? What would that part number be?
Old 03-24-2011, 10:23 PM   #16
Same as D75
Old 03-24-2011, 10:30 PM   #17
nobleboy
Thanks, CTScott! I will make my own connector some time in the next few weeks and repost when I have it working.
Old 03-24-2011, 10:34 PM   #18
I would just find terminals that fit the pins and then heat shrink them.
DIY: Aux Input Jack Adapter TinyGiant DIY / Maintenance / Service 11 11-10-2012 05:33 AM
Loose aux input? stellar In Car Entertainment + Electronics (audio / video / alarm) 9 08-14-2011 08:36 PM
Aux Input options Kru DIY / Maintenance / Service 3 10-30-2009 02:05 PM
High pitched whine using stock head unit / aux input? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 8 02-02-2007 12:49 PM
