Old 03-25-2011, 10:25 PM   #1
severous01
any tpms swaps out there? steel to aluminum?
i have steel rims and i want aftermarket aluminum wheels. did anyone come up with some definite answers about whether or not the tpms sensors will fit? i have a dremel, and a die-grinder. i have bits, cutters, grinders, sanding wheels, cut-off wheels, and just about anything else needed for slight modifications.
most newer style rims are tpms compatible as well as regular valve stem compatible. but there was some talk around here the last i heard that the steely tpms wouldnt work on rims.
Old 03-26-2011, 12:08 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
The TPMS valves from your steel wheels will definitely fit your new alloy wheels.
Old 03-26-2011, 07:10 PM   #3
severous01
awesome, thanks.
DIY - - -TPMS work around rningonfumes DIY / Maintenance / Service 6 03-03-2011 08:11 PM
TPMS light on after swapping 1 tire from different car nvidiaxtc DIY / Maintenance / Service 5 02-02-2011 09:45 PM
tpms compatibility? bwong2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-11-2009 09:33 AM
TPMS Gauges - do they exist? Sodium Duck DIY / Maintenance / Service 24 03-01-2009 12:18 AM
Mild Steel vs Stainless Steel ruimond Performance Modifications 18 01-02-2009 11:11 AM
