Old 03-30-2011, 10:35 AM   #1
jstantherprsn
Drives: 01 Toyota Echo
coil testing
Anyone know what i can do to check my coils over my plugs? I saw some thing using a test light. I was wondering if there was a tool a garage uses.
I'm familiar with the resistance testing on the high and low side.
Do they use a high pot test to measure the high pot resistance?
jstantherprsn is offline   Reply With Quote
Old 03-30-2011, 11:40 AM   #2
The coil packs contain more circuitry than traditional coils, so you can't get at the input side of the coil. You can partially get at the output side, but there is a diode between one leg of it and the +B terminal.
Old 03-30-2011, 06:53 PM   #3
jstantherprsn
damn it!
WTB 1NZ-fe Coil Packs (4) Moses Willing to Buy by private party 3 01-03-2011 03:22 PM
WTB: coil on plug connector Moses Willing to Buy by private party 1 12-15-2010 05:29 PM
replacing coil springs yaris9876 DIY / Maintenance / Service 2 07-11-2010 09:17 PM
NST Dyno Testing: BMW 335i N54 CR-Lite Crank Pulley NonStopTuning NonStopTuning 7 08-20-2009 05:19 PM
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 03:07 PM
