Old 04-01-2011, 06:16 PM   #1
Yarisaur
Drives: 07 Yaris
axle back problems?? wont bolt down firmly
just installed a DCsport axle back exhaust and the joint were it bolts up is loose..( i can move it around and the bolts are tight.. is it suppose to have play in it like this because its gasketless??
Yarisaur is offline   Reply With Quote
Old 04-01-2011, 06:19 PM   #2
auxmike
auxmike's Avatar
You'll know if you can hear or feel an exhaust leak.
Old 04-01-2011, 06:36 PM   #3
Yarisaur
Drives: 07 Yaris
Okay about to go for a drive and I will get under there and see if i can feel a leak..
Old 04-01-2011, 07:38 PM   #4
Yarisaur
Drives: 07 Yaris
Okay just checked it an it is leaking a little.. what do i do? everything is tight..
Old 04-01-2011, 10:14 PM   #5
shinlee
shinlee's Avatar
Drives: 07 liftback
I would go back and just unbolt and rebolt it back up, taking extra care that it's aligned right before you do the rebolting
shinlee is offline   Reply With Quote
Old 04-01-2011, 11:12 PM   #6
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
Do have the donut gasket in there Yarisaur? There should be a round polymer gasket that fits in the joint and gets sandwiched between the flanges under spring tension when the bolts are tight.
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Back hurt? yarswiss Off-topic / Other Cars / Everything else Discussions 10 11-14-2008 04:39 PM
Rear wiper: EZ mod so it pulls back all the way joelitton Cosmetic Modifications (Exterior/Interior) 10 10-22-2008 10:30 AM
FS: Tanabe Concept G axle back exhaust yrsdrgn Items for Sale by private party 9 08-20-2007 04:33 AM
Why are there only axle back exhaust??? hatchbackkid82 Performance Modifications 11 04-30-2007 05:54 PM
