Old 04-02-2011, 12:28 AM   #1
Taiyaki
アキバ製
Taiyaki's Avatar
Sub intallation help~
So I have two 12" CVRs 4ohms each @ 800rms (together) and a Kenwood mono amp that does 900rms @ 2ohms. I looked on the 12volt site for wiring diagrams but it only says how to wire them down to a 1ohm and 4ohm load.
How would I wire it to a 2ohm load?
Thank you
Old 04-02-2011, 01:05 AM   #2
sqcomp
Roadrunner Jr.
sqcomp's Avatar
If they're both single 4 Ohm, wire them in parallel. In a parallel circuit, the current flow increases and the impedance decreases.
― Thomas Paine
Old 04-02-2011, 01:31 AM   #3
Taiyaki
アキバ製
Taiyaki's Avatar
Oh sorry I forgot to say that they are DVC
Old 04-02-2011, 01:28 PM   #4
Lil Abner
Drives: 2009 3dr LB Manual
The subs, is each voice coil 4-ohms? So are they dual 4-, dual 2-, or dual 8-ohm subs? Your post is unclear.
Old 04-02-2011, 02:19 PM   #5
Taiyaki
アキバ製
Taiyaki's Avatar
Im going to say that the sub itself is 4ohms. Not each coil is 4ohms. All the kicker site specs say is "4ohm DVC". It doesnt go into any deeper detail sorry.
Old 04-02-2011, 02:25 PM   #6
Lil Abner
Are they these??
http://www.halfpricecaraudio.com/Kic...s-10CVR124.htm
Old 04-02-2011, 04:15 PM   #7
sqcomp
Roadrunner Jr.
sqcomp's Avatar
http://mobile.jlaudio.com/support_pages.php?page_id=161
Try this...
― Thomas Paine
Old 04-02-2011, 11:51 PM   #8
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Here is another one... LINK
D.
CLA 250, 4MATIC
Old 04-03-2011, 12:25 AM   #9
Taiyaki
アキバ製
Taiyaki's Avatar
Yeah pretty much the same but I have the Aluminized one
http://www.kicker.com/compvr_aluminized
I looked at both sites but I couldnt find how to wire two 4ohm DVC subs down to 2ohm load.
This is the amp that I bought
http://www.bestbuy.com/site/Kenwood+...&skuId=9763288
So would it be possible to wire my 4ohm DVC to 2ohm? Sorry Im kind of new to this
Old 04-03-2011, 12:29 AM   #10
Taiyaki
アキバ製
Taiyaki's Avatar
It says that my amp is 1ohm stable, but does that mean I can wire it parallel/parallel to 1ohm load and be ok? idk the specs says 900watts @ 2ohm.
Old 04-03-2011, 01:41 AM   #11
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
do you know how to tune the amp using a test tone? if so figure out how many watts the sub can take at 1Ohm and mutltiply it by the Ohms you want,then take the square root of that.
Then burn a test disk using say 50 hz tone,I get mine at realm of excursion......
Find out the 75% volume level of the deck....if deck goes to 40,then 30 is the highest you ever want to go to for most cases.
Start at amp with all gains down,crozzover points all the way down,play the tone disk at say 25% volume and when the tone gets the loudest,turn the crossover back just a bit till it starts to soften in volume.....now you are basically crossed at 50hz....good point to tune most subs.
Now we want to work the gains,using a DMM take the info you got at the square root of the watts x ohm and that is your AC currant from the amp going to the sub you want to bring gain up to.
Using the DMM turn up the gain with deck at 75% volume,tone disk playing,sub hooked up,and with DMM on the - and + of the amp turn the gain till you get that square root number and now amp is going to be perfectly tuned to correct outut of power.....now test the sub playing some tunes and see if amp gets hot,if it gets hot pretty quick then it is not liking being at 1Ohm.....
Old 04-03-2011, 01:43 AM   #12
bzinn 1
bzinn 1's Avatar
also you are corrct...2 D2 subs cannot be ran at 2 Ohm....just not possible...eiter 1 or 4 if I remember correctly
Old 04-03-2011, 02:55 AM   #13
Viperoni
Drives: 2005 Toyota Echo
Yes they can, coils in series and the subs in parallel.
To wire 2 D4 subs to 2ohms, just use one coil from each sub and wire the 2 coils in total in parallel.
2006 Saturn Ion Redline
Old 04-03-2011, 03:04 AM   #14
sqcomp
Roadrunner Jr.
sqcomp's Avatar
• 500 watts RMS x 1 at 4 ohms (900 watts x 1 at 2 ohms)
• 1-ohm stable (output regulated to 900 Watts)
http://www.kenwoodusa.com/Car_Entert...iers/KAC-9105D
^This is from the Kenwood site. Soooo....according to the manufacturer, you can run this at 1 Ohm.
2 DVC drivers with Voice Coils in Series / Parallel
Connecting the two voice coils of each driver in series (+ to -) and the drivers themselves in parallel (+ to +, etc.) will result in the following impedances:
Dual-4 Ohm Subwoofer: 4 Ohms
2 DVC drivers with Voice Coils in Parallel / Parallel
Connecting the voice coils of each driver in parallel (+ to +, - to -) and the drivers themselves in parallel (+ to +, etc.) will result in the following impedances:
Dual-4 Ohm Subwoofers: 1 Ohm
You CAN run ONE of the woofers into 2 ohms.
― Thomas Paine
Old 04-03-2011, 05:30 AM   #15
Taiyaki
アキバ製
Taiyaki's Avatar
Thank you! Ok so my amp can be wired to a 1ohm load. Excellent!
My next question is that there is a + and a + dot, same with the negatives. Would it be like this?
or would the dots be on the other side?
Old 04-03-2011, 09:57 AM   #16
Lil Abner
Yeah, that diagram looks correct for wiring your 2 subs into a 1-ohm load. Basically all the positives tied together, all the negatives tied together. Should be an easy install for you.
When you get it installed, make sure you're x-over is set correctly. Also, start with the gains down low. You don't want to fry anything.
Old 04-04-2011, 05:18 AM   #17
Taiyaki
アキバ製
Taiyaki's Avatar
Ok so Im not able to install my subs yet because im still making the custom box but for now Im just going to wire my amp and make sure everything is ok.
I have a box they came with and was wiring it but when I got to my mono amp, I saw that it had two speaker terminals (+ + and - -). So do I just use one + and one -?
Old 04-04-2011, 08:17 AM   #18
Lil Abner
Well, you're going to need to "bridge" the amplifier. The owner's manual should tell you which (+) and (-) terminals to use. Or look at the amplifier itself. Usually it tells you how to bridge the amp. But since it's a mono amp, I would assume you're correct to just use one (+) and one (-). But always best to read the manuals.
COLD AIR INTAKE availability and intallation in riyadh mayron kaya? amaze_2 Middle East 4 09-25-2010 02:26 AM
reupholster interior panels need help~ Taiyaki Cosmetic Modifications (Exterior/Interior) 18 08-25-2009 04:14 AM
Version 1.4 of the Blitz S/C Intallation Manual is available LtNoogie Forced Induction Forum 0 04-12-2009 01:49 AM
