Old 04-09-2011, 07:27 AM   #1
yarislady
yarislady's Avatar
Drives: 08 Yaris HB
About to turn 50k, any maintenance?
I was just wondering if there was any maintenance I need to do since it's turning 50k. I just did an oil change and replaced the tires so those should be good, maybe spark plugs or something along those lines?
yarislady is offline   Reply With Quote
Old 04-09-2011, 07:32 AM   #2
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Fugeaboutit. Literally, nothing but oil and oil filter changes until 100k. And don't let the dealer trick you into thinking something is due either.
Old 04-09-2011, 08:59 AM   #3
swidd
Drives: Yaris HB
Engine air filter, cabin air filter. Perhaps by next year around you should replace coolant at 4-year mark ($23 DIY, its easy). While not commonly mentioned much, after 3-4 years I would also replace brake fluid.
How long do you plan to keep the car anyway?
Old 04-10-2011, 06:35 AM   #4
yarislady
yarislady's Avatar
Drives: 08 Yaris HB
For a while, and thanks for the help. I still need to look and see if there actually is a cabin air filter. And another reason why I was asking about maintenance is the dummy light is flashing only at start up for about 20-30 seconds, then no light at all.
Old 04-10-2011, 06:59 AM   #5
rningonfumes
There probably isn't a cabin air filter as most of ours did not come with one. As for the light, it is definitely the maintenance light. It blinks on start up as you near 5000miles. Once it hits 5000 miles, the light will stay solid. This is every 5000 miles from when the light was last reset, not each 5000 miles on the odometer.
Old 04-10-2011, 07:32 AM   #6
yarislady
yarislady's Avatar
Drives: 08 Yaris HB
Ok thanks for the help, probably from the last time my girl got the oil changed. Did it myself because the guy put a sticker in the window, must have been set for 3000 not 5000. And if you are confused by that comment, I made this profile for my girl and she didn't take to it like I'd hoped and haven't found an admin to change it. So now I'm a guy stuck with this name till I do.
Old 04-10-2011, 07:47 AM   #7
rningonfumes
LOL...you're better off making a new profile since you have so few posts though there are mods around, the admin ( who have those powers) aren't around as often.
http://yarisworld.com/forums/showthread.php?t=24061 Maintenance requirements http://yarisworld.com/forums/showthread.php?t=3940 Resetting the light
You sound like you know your way around forums, those would answer your current questions.
As for the light, it can't be .... manipulated and only counts up to 5,000 miles. You can reset it sooner or later but if left untouch, it will go to 5,000.
Old 04-10-2011, 08:36 AM   #8
yarislady
yarislady's Avatar
Drives: 08 Yaris HB
Thanks and yes I am pretty avid at forums. Best way to go if you want to know anything about whatever your into. Ever car I have ever owned I find a forum for it lol.
Old 04-10-2011, 08:58 AM   #9
rningonfumes
That's my philosophy!
Old 04-10-2011, 04:44 PM   #10
2007yariz
Drives: Yaris sedan
If you drive in stop and go traffic alot maybe you could change the brake pads? Or is that good for 100k also rningonfumes?
2007yariz is offline   Reply With Quote
Old 04-10-2011, 06:59 PM   #11
rningonfumes
You have to inspect brakes to see if they require it. Some people stomp on their brakes every chance they get, others ride it like a pony at a fair, still others are conservative with them even in stop and go so it is dependent on the driver.
Old 04-10-2011, 07:25 PM   #12
swidd
Drives: Yaris HB
Batteries commonly only last 4 years, but some run them 6-8 years without problems...
Old 04-10-2011, 09:01 PM   #13
nemelek
DWEED
nemelek's Avatar
Don't forget the outside. Wax it if you haven't already.
Old 04-11-2011, 02:04 AM   #14
yarislady
yarislady's Avatar
Drives: 08 Yaris HB
Well see the car is my girls car, been tweaking a little here and there. Just got a system back in it, and took off the ratty hubcaps cause she likes turning a little too quick. Unfortunately for the body I have to wait a couple more weeks since we live in Ohio and the weather changes more then her moods lol jk. I am looking at replacing the battery because for some reason no matter what I do there is corrosion on the negative terminal. I think I need to check the ground for rust.
Sound when making a left turn (a water flow sound) jimmydie DIY / Maintenance / Service 9 06-20-2013 05:35 PM
4-wheel alignment for 5000 mi. maintenance????? Yari-Chan General Yaris / Vitz Discussion 44 01-28-2011 09:00 PM
How did $69 Maintenance turn into $311 ??? Any opinions greatly appreciated. sherriebythesea DIY / Maintenance / Service 28 10-11-2010 10:54 PM
Are rear red turn signals planned for Yaris as well ? 77W General Yaris / Vitz Discussion 38 02-22-2010 06:41 PM
Will local bay area members please stand up! YarisSedan California 264 07-28-2009 11:53 PM
