Old 04-11-2011, 01:13 PM   #1
Aarron_M
Aarron_M's Avatar
Drives: 2011 Toyota Yaris
Disabling Traction Control
2011 Yaris 3dr LB base model. 5spd. Anyone know how to disable traction control? Is there a fuse or something? I know the S model has a switch...
Aarron_M is offline   Reply With Quote
Old 04-12-2011, 07:15 AM   #2
rick996
rick996's Avatar
Drives: 2010 5 door hatch w/5 sp man.
There is a multi step procedure that works on my 2010. When you shut the car off TC is set back on again. I only use it in the winter if I have a tough hill to climb without a running start. See:
http://www.yarisworld.com/forums/showthread.php?t=33027
rick996 is offline   Reply With Quote
Old 04-12-2011, 07:21 AM   #3
Aarron_M
Aarron_M's Avatar
for the 09-10 models
car off, hand brake up
start car
depress brake 2 times brake brake (hold 2nd brake while doing next step)
handbrake down, up, down, up
release brake and depress brake 2 more times
your trac light should then come on and will turn off when u turn the car off..so u gotta do this every time you start the car. if you start the car and wait over a min, u will have to turn off car and start over. if you screw up the sequence, just turn the car off and start over.
This? Seems like a nintendo cheat code. Guess there's no way to permanently disable it? I mean come on, the car has 100hp, not 300 like my STi that didn't have traction control.
Old 02-20-2013, 08:46 AM   #4
Captain Slow
My Face Is Ridiculous
Captain Slow's Avatar
Drives: 2010 Toyota Yaris 3dr LB
i kinda think it's badass that we have to remember a "cheat code" to disable it...that said I just wish I could actually REMEMBER it, hence why I'm looking it up yet again today, lol.
Captain Slow is offline   Reply With Quote
Old 02-20-2013, 09:09 AM   #5
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
i don't think my 09 has traction control.
Old 02-20-2013, 09:18 PM   #6
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
that is why i am glad i bought the first model year, no traction control, no abs, no nannies whatsoever. Although from reviews they are finally coming out with tc and nannies that don't destroy driving entertainment.
Colin Chapman disciple
Old 02-21-2013, 08:38 AM   #7
Captain Slow
I used to hate all of the electronic safeties...but they've actually come in handy a few times. It's nice to know that it's there in wet weather. If I want to break traction on purpose I can just do the cheat code ;)
Old 02-21-2013, 08:57 AM   #8
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
I have a 2010 s type where is the switch?
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Check Engine and Traction Control Light On limey163 DIY / Maintenance / Service 21 07-14-2013 03:03 PM
Traction Control Removal bronzebullet232 Performance Modifications 35 12-23-2010 04:09 PM
any how to's to disengage the traction control? OTA'sTOY DIY / Maintenance / Service 8 04-06-2010 04:26 PM
