Old 01-13-2007, 10:56 AM   #1
Ryu
Tire Fitment question
Just need a quick question for this one.
My original stock one is P175/65R 14 tire for 5 DR Yaris Hatchback.
I am planning to get All-Season Michelin Hydroedge tire for it and the spec is
P185/65R 14 or P185/70R14.
Will any of those fit onto my yaris and which one might fit better?
I am not familiar with fitment of tire, need help
Old 01-13-2007, 11:56 AM   #2
03Z33
03Z33's Avatar
Drives: TCR10
The 185/65/14 is almost identical size as your stock tire and will fit good. It's just a little bit taller but not enough to make a difference.
03Z33 is offline   Reply With Quote
Old 01-13-2007, 12:01 PM   #3
YamilR
YamilR's Avatar
Drives: Absolutely Red Liftback
Send a message via Yahoo to YamilR
I'll stick with 185 65 14, if you use the table below it will tell you that you're 2.2% below and you want to keep it below 3%
http://www.miata.net/garage/tirecalc.html
YamilR is offline   Reply With Quote
Old 01-13-2007, 12:14 PM   #4
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
That tire calculation chart is extremly useful. Very cool!
Old 01-13-2007, 01:35 PM   #5
Ryu
Thanks guys for quick response
Old 01-14-2007, 01:47 AM   #6
SmellyTofu
好多人&
Drives: .
You'll find 185/60R14 should have an array of performance options. This size was very common amongst the 80's and early 90's for small performance car tyre size.
Failing that, if you want to go 15", 195/50R15 is your next step up.
Yaris/Vitz fitment question MrMondayNite General Yaris / Vitz Discussion 2 11-07-2006 08:41 PM
Wheel and tire question. EddyCocaine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 08-31-2006 11:13 AM
Flat tire, totally ruin help David81 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-15-2006 01:54 PM
Tire Question Chaad32 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 08-06-2006 09:53 AM
