Old 04-14-2011, 08:50 PM   #1
JohnnyBomber101
JohnnyBomber101's Avatar
Drives: 2008 Yaris 3dr
Spoiler attachment question
I have read every post that the word "spoiler" comes up with in search. I can not find anything on how to attach one of the "J's" style spoilers to the Yaris Hatch. I have been looking at pics of several HBs that have them and I can only assume that they have drilled holes and used sheet metal screws or something like that.
Does this sound correct to anyone? Does anyone have any advice on this? The top of the hatch is double walled, so I can not use a nut and bolt setup.
Could someone let me know the method they used?
"No problem is insoluble, with the correct application of explosives."
EOD - because firefighters need heroes too...
Scoliosis - because real women have curves!
JohnnyBomber101 is offline   Reply With Quote
Old 04-14-2011, 09:23 PM   #2
Brian
Brian's Avatar
When I installed an OEM spoiler on a LB, I had to drill 4 holes in the outer skin. It was held in place with 2 clips and two rubber plugs. The rubber plugs had a threaded metal center and when the bolts are inserted and tightened they expand to secure it in the hole. The spoiler also had double sided tape for added security.
Old 04-14-2011, 09:54 PM   #3
JohnnyBomber101
Thanks Brian. I will check with Toyota on those plugs.
Old 04-14-2011, 10:10 PM   #4
Brian
Brian's Avatar
P/n is 76865-52030 for the rubber retainer and p/n for the screw is 90159-60431. Its about $4 for the retainer and about $.75 for the screw.
Rear Spoiler SWAP?? From 08 to 09 TRDMarty General Yaris / Vitz Discussion 4 03-18-2011 04:30 PM
TRD Vios Spoiler fitment? AdeJong 03 Cosmetic Modifications (Exterior/Interior) 12 08-24-2009 09:06 PM
2009 Spoiler Question pariahdecss Cosmetic Modifications (Exterior/Interior) 16 12-19-2008 11:22 PM
RS Spoiler (Yes i tried to search it!!) hasher22 Cosmetic Modifications (Exterior/Interior) 2 08-23-2007 11:02 PM
RS Spoiler price question Sway84 Cosmetic Modifications (Exterior/Interior) 3 06-04-2007 10:35 PM
