Old 04-20-2011, 11:16 AM   #1
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
tachometer advice
I have been looking for the right tach for me but I have been having some major fitment issues.
I really don't like putting it on the A pillar or close to that. I thought about putting it in the drivers side glove box but I worry about how small it will have to be to fit in there.
I am alright with mounting it to the steering column but then the clearance becomes an issue with opening the drivers side glove box.
I was thinking of 2.5-3.75 inches in diameter. the best I can tell, the clearance goes down to 2 inches between the steering wheel and the glove box door when it is being opened.
I would like a black faced tach and one that only sweeps to 8k.
after almost a week of frustratingly looking around, any advice is welcomed.
thanks
thebeef
Old 04-20-2011, 11:31 AM   #2
1. You'll have to pick between 2 1/16" and 3 3/8".
2. Get a name brand. (Autometer good, Glowshift bad, for example)
3. You actually use your driver glovebox? There is plenty of storage up front. You have to give something up to have a tach in front of you.
4. A tach should be where you can see it easily, or it's useless -- IMO.
I guess me PM-ing you this same info wasn't convincing - lol.
Autometer ES, GS, Nexus, ProComp, all black face, fyi
Old 04-20-2011, 11:34 AM   #3
BEEF
BEEF's Avatar
I found some slim tachs but they were all the 5" monsters. I was hoping that someone would know of a vendor of a slim one that was in the 3" range.
I know, I am asking a lot but I was hoping for someone to come out of the woodwork on this one.
I have come to respect your opinion very much but at the same time, nobody can know it all.
Old 04-20-2011, 11:37 AM   #4
might take a bit of fabbing, but why not mount it on the glovebox lid itself, so you could still open it?
Old 04-20-2011, 11:41 AM   #5
BEEF
BEEF's Avatar
I've done body work before and well my work is eh....yea. probably not going to work out too well if I do it.
I may just sacrifice the use of that compartment and get the 3 3/8 one. i can't really see myself using a little 2 inch one.
garm actually has a gauge cluster that can go there and will house 3 gauges. I thought hard about that one.
Old 04-20-2011, 12:49 PM   #6
^ that would work. You could also put the 3 3/8" tach on a cup that mounts to the glovebox. No fabbing, glovebox opens. I'm not sure what you're still looking for?
Old 04-20-2011, 12:52 PM   #7
BEEF
BEEF's Avatar
wow, that is a really good point.
sometimes the obvious eludes me. thanks I think I am going to buy a tach now.
Old 04-20-2011, 03:11 PM   #8
^ COOL, you will love it. I can't have a vehicle without a tach; I even added one to my vintage micro car.
Old 04-20-2011, 03:28 PM   #9
RedRide
RedRide's Avatar
I took "Altitude's" adivse in this tread and installed this "Revolution" tach from "Speedhut" (in the same location on the steering column as he did) and I'm very satisfied with it. (scroll down)
http://www.yarisworld.com/forums/sho...install&page=7
It is a bit expensive but, worth it IMO as you can order it in many configurations and colors, different gauge faces etc.
(I ordered one that looks just like his.)
It also makes a very clean looking install.
http://www.speedhut.com/custom_gauge...number-694.htm
I just have it mounted with some 3M double faced tape and it's fine. It may be just what you are looking for.
Old 04-20-2011, 03:34 PM   #10
90tsi
90tsi's Avatar
Drives: 09 yaris
I put my prosport on my steering column and still access to my drivers glove. I believe its a 3 3/8's bit im not exactly sure but i know its at least a 3inch
90tsi is offline   Reply With Quote
Old 04-20-2011, 10:07 PM   #11
Revsson
http://www.yarisworld.com/forums/sho...&postcount=125
That is a clean looking install.
but like you said.....pricey.
Old 04-21-2011, 12:32 PM   #12
RedRide
RedRide's Avatar
IMO, if you spend $1400 fo a car, $130 is not too much to spend for a tach.
Old 04-21-2011, 01:08 PM   #13
^ +100
Old 04-21-2011, 05:25 PM   #14
RedRide
RedRide's Avatar
BTW, the "Revolution" tach can also be panel mounted using the included hardware.
Its thin profile makes it also ideal to mount in on/in the door above/behind the steering column.
However, I chose to just use the pedistal mount and not cut into anything.
Old 04-25-2011, 07:12 PM   #15
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
My Autometer tach:
http://www.subcompactculture.com/200...l-economy.html
Old 04-25-2011, 08:05 PM   #16
Revsson
Interesting blog.
At what rpm do you find yourself shifting?
I have a tach I haven't installed (Sunpro CP2012) mostly because it has
the white face. The black face would look better.
I also bought a Scangauge II from Garm that I haven't installed yet.
Now that the weather is getting better, perhaps I will make some decisions
on what to install and where.
I should probably sell it to someone that still has a 3 cyl Geo Metro, since
it can be set for 2 or 3 cylinders.
Here is a link to what the black one looks like:
http://www.yarisworld.com/forums/sho...2&postcount=84
and here is what my whitefaced one looks like.
Old 04-25-2011, 11:10 PM   #17
Thirty-Nine
Originally Posted by Revsson View Post
Interesting blog.
I tend to shift at around 3,000 for daily driving.
Old 04-26-2011, 02:03 AM   #18
TEHxFALLEN V1.2
TEHxFALLEN V1.2's Avatar
Drives: '08 Lexus IS-F
Sponsored by: Micro Image
http://microimageonline.com
Need advice on head unit settings chewychewbacca In Car Entertainment + Electronics (audio / video / alarm) 18 03-18-2011 06:54 AM
Manual with no tachometer tips maineyaris General Yaris / Vitz Discussion 10 02-01-2011 04:42 PM
Yaris 06 T Spirit advice needed ! nocturne_sa General Yaris / Vitz Discussion 1 01-03-2010 05:24 AM
Good advice for new car owners... YarisSedan General Yaris / Vitz Discussion 10 04-15-2009 03:43 PM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 12:41 AM
