Old 04-24-2011, 06:12 AM   #1
blacks
Drives: toyota yaris sedan
A/C STOP LEAK
Hi guys what's the best a/c stop leak out there ?
And does it work as good as they say
blacks is offline   Reply With Quote
Old 04-24-2011, 06:25 AM   #2
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
From another forum =
Gold Enthusiast replies
I have been an automotive technician for over 25 years and in automotive engineering for one of the big three for 15 years. I never seen a stop leak product that worked on an A/C system!
If you had a leak at the compressor it more than likely was the shaft seal. For a stop leak product to stop the seal leak it has to swell the seal. That means that every rubber piece in the system will be swollen also. Oh Oh now for the really bad part! The swelling softens the rubber to the point that it will weaken every hose! The A/C system will run up to 300 psi. So you see what will happen?
Now for the other leak! If you condenser was leaking it more than likely has a hole in the metal. For the stop leak to fix that, it will have to plug the hole with something. That can be done like stop leak for a radiator. But here comes the bad news again! An A/C system has an orifice in the line to create a high and low, pressure difference. The orifice is a very small hole! Can you see what is coming? Around the orifice is a screen the filters out particles (mostly metal from wear in the compressor) that flow through the system. This will plug up and the high-pressure switch will shut down the compressor. Not good!
Old 04-24-2011, 08:45 AM   #3
1stToyota
1stToyota's Avatar
Probably the only thing it's good at is damaging expensive a/c service equipment when they hook up to the vehicle.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 04-24-2011, 10:20 AM   #4
blacks
Thanks alot for the advice guys
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
A/C Broken On My 2010 5 DR HB ChilliwackGuy DIY / Maintenance / Service 15 07-14-2010 04:33 PM
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
