Old 04-24-2011, 05:48 PM   #1
matthewai
matthewai's Avatar
Drives: it is kinda stock
Question white film after cleaning tires/steelys
just used meguires hot rims and armor all tire foam (not at the same time 2 different days) both of them left a white film i followed the directions what the fugg any suggestions on other good wheel stuff or why its leaving the white residue ?
Old 04-24-2011, 06:43 PM   #2
Klink10
Klink10's Avatar
The white residue on the tires is from the actual mold used to make the tire. It is a grease like substance sprayed in and then the rubber is poured. All is then sealed and heated. The mold lube allows the tire to seperate from the mold. It eventually will wear off. It is a beyotch to get off if you can't wait. I just clean with a APC and treat with Stoners. The wheels get normal wash and LSP is until I get rid of my supply, Megs NXT 2.0 sealant.
Old 05-11-2011, 06:50 PM   #3
AppleJacks716
Drives: 2010 5 Door
Get a tire cleaner and give the tire a good scrub. It shouldn't leave a film. I wouldn't use tire shine often. Tire shine tends to dry rot the side walls of the tire over time with excessive use.
AppleJacks716 is offline   Reply With Quote
Old 05-15-2011, 09:46 AM   #4
A pressure washer works great at removing anything from the tires.
Old 05-15-2011, 09:37 PM   #5
Klink10
Klink10's Avatar
Pressure washer does well. Just don't get to close with a high power one.....I know.
Old 05-16-2011, 01:05 AM   #6
matthewai
matthewai's Avatar
will try
Yarisworld Decal -SHOW YOUR YW PRIDE!! Astroman Items for Sale by private party 235 08-21-2019 10:45 AM
white yaris; white wheels? botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 02-07-2009 10:20 AM
So Hasher now has a sexy ride...... hasher22 Photo-Video-Media Gallery 15 06-09-2007 07:33 AM
White on white d2dailly Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 02-27-2007 08:09 AM
