Old 05-03-2011, 08:45 PM   #1
Midnightsun
Drives: 2006 Yaris RS 5DR White
Need advice for new door speakers all around
Can somebody help me out here. I am installing a sub and amp for the sub and would like to upgrade the door speakers in all 4 doors of my 2006 Yaris Hatchback (same as 2007-08) What fits relatively easy in the existing holes or do I need to add any special spacers. So what do I need. 6 1/2" all around? Any recommended brands relatively cheap? Do I need to worry about depth?
Midnightsun is offline   Reply With Quote
Old 05-03-2011, 09:02 PM   #2
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Did you check out this thread?
In my 2008 LB it's 6.5 up front and 5.25 rear unless you want to do some modifications. You will likely need to fabricate some spacers, but maybe there are some aftermarket ones available now. I made some for myself out of MDF using the templates from post #28 in the thread posted above. I think some have even used the stock speakers with the guts removed. If you do a search on speaker spacers I'm sure you'll get some ideas.
Old 05-04-2011, 05:57 AM   #3
Midnightsun
Thanks for the response. Since I need to manufacture adapters, there seems to be ample room to oversize. Can I go 6 3/4" up front like these? http://www.crutchfield.com/S-vxkPkAS...tml?tab=review
Need advice on head unit settings chewychewbacca In Car Entertainment + Electronics (audio / video / alarm) 18 03-18-2011 06:54 AM
General service/maintenance advice dweaver3481 DIY / Maintenance / Service 2 03-14-2011 11:06 AM
Yaris 06 T Spirit advice needed ! nocturne_sa General Yaris / Vitz Discussion 1 01-03-2010 05:24 AM
Good advice for new car owners... YarisSedan General Yaris / Vitz Discussion 10 04-15-2009 03:43 PM
