Old 05-05-2011, 01:48 PM   #1
dchurchwell
Pizza D
Drives: 2007 yaris 3D MT
Higher tire pressure=less turning ability??
I deliver pizzas and have take turns at the highest speed possible...so should I still crank up the pressure? I already squeal the tires about once a day while turning.
dchurchwell is offline   Reply With Quote
Old 05-05-2011, 01:52 PM   #2
dchurchwell
Pizza D
Also i live in FL so the temp will be over 100 in not too long.
Old 05-05-2011, 02:56 PM   #3
STC
"LibertyRides!"
STC's Avatar
You will have turning ability, but at higher psi you will have less turning 'traction'. For your case I would use around 30 -32 psi. IMHO.
Cheers!
~ Mark ~
Old 05-05-2011, 08:49 PM   #4
ecc_33
ecc_33's Avatar
Drives: 2008 toyota yaris
If you crank the psi in the tires say the tire is cold and you have it at 50psi. If it is 90* outside you might have a "hot" tire pressure of upwards of around 65psi. This is why I NEVER run more than what the sidewall on the tire says. Its stupid to run more for a couple extra pennys when you don't know what could happen to you or others.
08 toyota yaris with some big tires lol
02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
ecc_33 is offline   Reply With Quote
Old 05-07-2011, 09:56 AM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
i would agree you should just run the pressure at 32psi. The other thing I would mention is you should not be able to reach speeds where traction would be limited on public roads, unless you start doing crazy u-turns. A speeding ticket kills income on any driving job.
Colin Chapman disciple
NITROGEN GAS TIRE FILL: WORTH IT? EjDaPogi Middle East 15 03-20-2011 02:06 AM
Higher tire pressure and winter handling? TwoBearWisconsin Fuel Economy Forum 15 03-01-2010 09:14 PM
Higher Tire Pressure captainm27 General Yaris / Vitz Discussion 46 01-27-2009 10:17 AM
